problem with activate() method of nested occurrences
Simple C++ script to demonstrate problem (-> attached file):
1) create new occurrence/component in active component
2) create sketch in new component
3) activate new component
Works as expected if root-component is active when user starts script:
-> component is activated, user can select sketch in timeline, right-click "edit sketch", create circle, stop sketch, create extrusion.
-> component activated
circle clearly visible after "stop sketch"
Works not as expected if "subassy" is active when user starts script:
-> new component is added, but in an "half-active" state. Timeline looks as if the component is activated, but no active-component radio button in the browser is visible. No component item in the browser is activated at all.
Question: known limitation?
If the user ignores this weird state, it can cause problems:
- user selects sketch in timeline, right-click "edit sketch", creates geometry, then "stop sketch" -> see image, faint display of circle, no component selected in browser
Then the user creates an extrusion with the circle.
-> see image
oops!
Addendum: if the user leaves the sketch directly by entering "create extrusion" (instead of "stop sketch" and then "create extrusion") then the extrusion is created without any warnings (and the new component is selected in the browser).
MichaelT_123
Hi Mr. Steinbach,
 ... it is difficult and time-consuming to give the definitive strict diagnosis but,
when creating extrusion make sure that the following are addressed:
# Get the value of the property.
propertyValue = extrudeFeatureInput_var.creationOccurrence
propertyValue = profile_var.assemblyContext
Regards
MichaelT
MichaelT
Just for clarification to avoid misunderstandings:
the example/demonstration C++ script just creates an occurrence in the active object, adds a sketch and activates the occurrence.
The rest of the operations (open/edit sketch, add circle, add extrusion) are done by the user interactively. Just to show what problems might arise when a user runs that script (which is actually only a part of a larger program).
My problem/question is: why does the API return a semi-activated occurrence, when the occurrence is created in a subassembly (in a non-root component/occurrence).
MichaelT_123
Hi Mr. Steinbach
There are many strange behaviors in F360 and depends upon a point of view (from below, from above, from ground level) they could be attributed to devilish work, miracle, someone's fatty fingers or ... misunderstandings of things by me, you and others.
Thank you for the clarification. Regardless of WHO created the strings of commands, they are at the end processed by the same(?) F360 core.
In your case, you are the co-author, sharing responsibility for the final outcome ( or failure).
I do not have time to C-compile and run your script but consider looking into the following:
- <<newOcc = activeComp->occurrences()->addNewComponent(matrix);>> does not create full contextual path to the occurence if it is not at root level
As a fact, if the active component has many occurrences representations, the command will 'create' respective number of occurences.
- <<Ptr<Sketch> sketch = newComp->sketches()->add(xy);>> Based on documentation when planarEntity is deep in the assembly, the different command's construct should be used.
<<returnValue = sketches_var->add(planarEntity, occurrenceForCreation);>>
- it seems that in your code, you did not cupture occurrenceForCreation and as such you can not build assembly context for entities you create.
Hopefully, this will help...
Regards
MichaelT
MichaelT
Hi Mr. Tomsia,
thank you very much for your time and your hints!
It helped me to find a way to achieve what I wanted - problem solved!
->createForAssemblyContext() did the job.
Ptr<Occurrence> newOcc = activeComp->occurrences()->addNewComponent(Matrix3D::create())->createForAssemblyContext(activeOccurrence);	// new occurrence
Kind regards,
