Problem renaming model parameters
brad.bylls
brad.bylls
I am trying to rename and reset values of model parameters.
Everything I find in the forums and help files say this should work, but no luck.
Here is the code I am using:
        product = app.activeProduct
        param = product.rootComponent.modelParameters.itemByName('d1')  << This line seems ok, no error
        param.value = BodyLength  <<  This line throws the error below
        param.name = 'Screw_Length'  << I reversed these two and this one also throws the error
Brad Bylls
brad.bylls
Looks like the screen shot of the error was removed.
It said:
Attribute Error: 'None Type' object has no attribute 'value'
Brad Bylls
KrisKaplan
Brad,
itemByName will return None if there is no item with that name in the collection. It will not raise an exception in this case (because it isn't really an error, the search was successful just with no result found). So you should check the returned parameter is not None to determine if the search found any match.
Kris
Kris Kaplan
brad.bylls
Thanks Kris.
I'll try to figure out where in the code it needs to go.
Brad Bylls
