My API script won't run with imported modules?
esumft
esumft
I've tried to import some additional modules into an API script, but when I run in Fusion it doesn't run the script? I have a feeling this is to do with relative imports, but I find it confusing about what I need to put where for using that.
import adsk.core, adsk.fusion, adsk.cam, traceback, time, os, serial
marcinszydlowski.1984
All dependent modules must be inside your plugin/script directory. Assuming such structure:
plugindir
 ├ Modules
 │  └ SomeUtils.py
 └ somethingmaker.py
You need to include imports as relative paths (it doesn't work as global in F360) in somethingmaker.py:
import adsk.core, adsk.fusion, ...
from .Modules import SomeUtils  # custom modules here
esumft
It's an odd one because this is my structure:
plugindir
 ├ Modules
 │  └ Second.py
 └ Main.py
In main.py:
from .Modules import Second
This returns the error in VS code, Fusion just doesn't run the addin:
Attempted relative import beyond top-level packagepylint(relative-beyond-top-level)
Script which needs to be run as an addin should contain *.manifest file. I've prepared two test plugins - one as a script and another as a plugin.
Script must be added in the first tab of the "Scripts and Add-Ins" window:
Then choose a directory with the script.
Plugin as addin must be added in the second tab (also choose the folder):
When you run the plugin, you should see its icon in the bottom of "SOLID" space "CREATE" panel.
Both zips contains nearly the same code which uses custom module. Main differences between the script and the plugin are:
- script has "DestroyHandler" whereas addin "stop(context)" method,
- script is executed (command is created) immediately in the "run(context)" method,
- addin uses *.manifest file with the same name as the ONLY script in the folder,
- command created in addin must be added to the interface - "run(context)" method.
If you want to create plugins and put them to the store, remember to attach *.pyc files of your modules, otherwise, they will be created in the runtime and during uninstallation they won't be deleted.
esumft
Thanks for your reply and for the examples! I'm still struggling to see what the link is to my relative import problem?
