Print Studio Extrusion issues with Ultimaker 2 extended
I'm having issues with extrusion in print studio files.
When I export the files from print studio to gcode to 3d print in ultimaker, it has issues with extrusion. When I compare the results of the gcode from cura, it shows that the ecodes and fcodes are vastly different numerically. I've had to go in and change the numbers several times in the code, comparing the range differences from Cura to Print Studio. Is anyone else having this issue or know how to help? I've attached a screen shot to show the comparison of the codes..
paul.clauss
Hi @Anonymous
Thanks for posting! Unfortunately, Print Studio is no longer a supported product and I cannot provide any insight into why the codes generated by Cura and PS are different. This is likely due to a change in the Ultimaker program that has not been addressed in PS as it is no longer being actively developed.
Cura is the print utility for the Ultimaker printers and I would recommend using it for your 3D printing needs, particularly when using the Ultimaker printers. We hope to replace PS completely with Autodesk Netfabb in the future - you could also experiment with Netfabb.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
