Helical gear generator
Hi I uninstalled the Helical gear generator and then re installed it but now I cant see it in the create drop down? I did re install it again and get the message that it is installed already do I want to repair. I have tried all options. Any ideas?
Click the ADD-INS menu item
Click the ADD-INS tab
Select the HelicalGear addin
Check "Run on Startup" at the bottom of the dialog
Then click Run
Hi thanks for the reply, I did not see helical grear in the add ins menu so
I re installed Fusion and all was fine then I was able to installthe
helical gear generator and use it.
