Post Processor
Post Processor
johnvgallagher
Post Processor
johnvgallagher
I am curious to know if there are post processors for Emco pc55 mills and lathes. Does anyone know if these have been mad available?
Thanks, John
brianrepp
Hey @johnvgallagher - have you seen this post on the CAM forums?  Might give a bit more insight on the posts and where to look for more info.
ArjanDijk
Hi @johnvgallagher,
I have both machines running on WinCAM, I import the code using an adjusted standard post.
The post you need depends on the control you have (siemens 810/840D/ Heidenhain/Fanuc). What control do you run?
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
johnvgallagher
Yes, both machines run on Fanuc
johnvgallagher
Arjancncmachinework,
Both my Emco mill and lathe use GE Fanuc Series O. How can I get the post
for these machines?
John
