Possible to transfer Configuration setup from a component into a new project?
Hello.
I have no real knowledge of Scripts or coding. But I am sort of looking into Fusion 360 scripting at the moment. I have no idea if I can execute what I wanna do or if it's even possible, so Im checking in here and see if anyone could just tell me if its a possability at least.
I am currently exploring ways to streamline and make a workflow where Im making a library of base components, that can be added into a new project. Components has a configuration setup but is currently not accessable when I import a component into a project.
I want to be able to import a component and then just open configuration inside the project and alter measurements for that specific part (locally and not change it in the original file,). Currently you can unlink the component but that just creates a stream of parameters which is not categorized per component but instead clumped. Dunno if its possible to make something that separates them, or if its possible to make it so the configuration is added automatically when unlinking.
Furthermore I also am trying to make a parts list that has adapted parts names as I use them as article numbers. so if I change the length, the name changes the number to that length (For example Article number would be "KSO[Length_1]L". If Length_1=900. the parts name would be "KSO900L" on the parts list. If I make changes into the parameter the number changes as well in the parts list. No idea if this is possible but maybe some code savvy person can tell me if this would be possible.
Im just trying to streamline certain workflows and make it as easy as possible to manipulate with minimal effort.
