permanently change VSCode settings.json
m0d0
m0d0
is there a way to change the workspace settings of VSCode permanently? (for adding linter configuration etc.) It seems like the  .../API/AddIns/<my_addin>/.cscode/setting.json file is overwritten at every run of the addin?
Thank you.
kandennti
Hi @m0d0 .
For windows, I think that the two files "settings.json" and "launch.json" have been copied from the following folders.
C:\Users\<username>\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\Python\vscode
m0d0
Thanks for your answer.
This will work but there are two drawbacks in our case:
1.  we can not share the settings via git (the repository is the addin folder)
2. this file probably gets overwritten as well every time fusion gets an update
So modifying the way the python interpreter is launched and setup would probably be more convenient.
Or is there an other solution achieving a stable setup for VSCode?
