Oriented bounding box
rolandas_vegis
rolandas_vegis
The BRepBody.orientedMinimumBoundingBox Property has been in Preview for 10months now.
When using this method of getting a orientedMinimumBoundingBox ir works wrong sometimes:
		const auto physicalProperties = body->getPhysicalProperties(HighCalculationAccuracy);
		JCAD_ASSERT_FUSION_RESULT(physicalProperties);
		Ptr<Vector3D> xAxis;
		Ptr<Vector3D> yAxis;
		Ptr<Vector3D> zAxis;
		JCAD_ASSERT_FUSION_RESULT(physicalProperties->getPrincipalAxes(xAxis, yAxis, zAxis));
		return Application::get()->measureManager()->getOrientedBoundingBox(body, xAxis, yAxis);
But the property on BrepBody works correctly.
Is it safe to release the BRepBody.orientedMinimumBoundingBox to users now?
BrianEkins
I'm sure this is an oversight, and the BRepBody.orientedMinimumBoundingBox property is OK to use.
Do you have an example model where the MeasureManager.getOrientedBoundingBox fails? I tried it with a random model, and it worked OK, so it must be a case-specific issue.
Brian Ekins
rolandas_vegis
Thanks, great that we can use it.
Yes, we issue is case specific.
Link to model: https://a360.co/3YK6yX3
Also an image showing for which component the box is wrong. MeasureManager.getOrientedBoundingBox returns sligthly rotated box, while BRepBody.orientedMinimumBoundingBox returns the correct box for this component.
BrianEkins
The MeasureManager.getOrientedBoundingBox and BRepBody.orientedMinimumBoundingBox differ in what they do and what you would use them for. The BRepBody orientedMinimumBoundingBox method doesn't require any input and calculates a tight-fitting bounding box for the body. The resulting box can be in any orientation to give the best fitting box.
The getOrientedBoundingBox of MeasureManager calculates a bounding box using the orientation you specify. It doesn't try to find the best fit. I get the same result as the minimum bounding box when I call this using the X and Y axes as the orientation. I don't know what directions you're using for the getOrientedBoundingBox.
Brian Ekins
rolandas_vegis
Thanks for explaining the difference, I was using it wrong then.
