Set post properties via API
Josh3GG88
Josh3GG88
hi. i am struggling with setting a property to a value using API. I have managed to edit my post to show the post Properties in the operations tab, but when i try to give that a value, i am getting an error.
kandennti
Hi @Josh3GG88 -San.
I don't think anyone can answer this question because the text in the video is small and it is unclear what the property name is, and I don't know what the cps file is.
At the very least, you need the code and the cps file for the part where the properties are set.
The following sample enumerates the post property names and Value type names and values for the first NC program.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = app.activeProduct
        ncPro: cam.NCProgram = camObj.ncPrograms[0]
        for postPrm in ncPro.postParameters:
            msg = f"{postPrm.name} : {postPrm.value.objectType}"
            try:
                msg += f" : {postPrm.value.value}"
            except:
                pass
            print(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
boopathi.sivakumar
Hi @Josh3GG88
Seems like you are trying to set the operation properties before even the operation is created.
Instead try after creating the operation
contour2dOp.parameters.itemByName('opProp_hoodPosition').expression = '2'
Boopathi Sivakumar
Senior Technology Consultant
Josh3GG88
thanks for the point out. i can now adjust the value after i have created the operation. works very good
Josh3GG88
Just thought I might ask. Is it a better practice to apply the operation property settings before or after creating the operation, or doesn't it matter?
