Only Write Certain Parameters To A CSV File
isocam
isocam
Can anybody help?
I have the following script that outputs Parameters to a CSV File.
#Author-Darren James Smith
#Description-Export Parameters To File
import adsk.core, adsk.fusion, adsk.cam, traceback, csv, subprocess
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
filename = "C:\Windows\Temp\Parameters.txt"
writeParametersToFile(filename)
#subprocess.run('C:\Program Files\PMM\Configure.exe')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def writeParametersToFile(filePath):
design = app.activeProduct
with open(filePath, 'w', newline='') as csvFile:
csvWriter = csv.writer(csvFile, dialect=csv.excel)
for param in design.allParameters:
try:
paramUnit = param.unit
except:
paramUnit = ""
csvWriter.writerow([param.name, param.expression])
I have a set of 25 parameters but I only want to save certain parameters to the CSV file.
The parameters that I want to save are:
CentreX
CentreY
DimensionA
DimensionB
DimensionC
Can anybody modify the script, above, to only output the parameters that I want?
Many thanks in advance!!!!
Darren
pludikar
Hi @isocam
This should do what you want
parameters = ['CentreX', 'CentreY', 'DimensionA', 'DimensionB', 'DimensionC']
def run(context):
    ui = None
    try:
    except:
        if ui:
    with open(filePath, 'w+', newline='') as csvFile:
            try:
            except:
                paramUnit = ""
            if param.name in parameters:
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
