onExecute fired when moved project, I want to cancel processing
Daisuke.Inokuma1
Daisuke.Inokuma1
I noticed onExecute event fired when I move a project with taking out command GUI.
When I pushed the OK button, I want to run [OK] processing.
When I movied project, I want to run [cancel] processing.
However, I think that I cannot distinguish me with the argument of onExecute.
(The left image is OK pressed eventArgs, the right when moved project. I think same two)
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        cmd = adsk.core.Command.cast(args.command)
        onExecute = ExecuteHandler()
        cmd.execute.add(onExecute)
        _handlers.append(onExecute)
        # omit other code
class ExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.CommandEventArgs.cast(args)  # <- Dump this
        # [OK] processing
        # omit other code
What should I do?
thomasa88
What do you mean by "move project"? Can you exemplify how you do this?
Try setting cmd.isExecutedWhenPreEmpted = False
Daisuke.Inokuma1
Sorry to noisy word.
In other word, changing current project.
I tried it and solved it.
Thank you for your valuable answer!
