OK Button Control
OK Button Control
kandennti
Mentor Mentor
OK Button Control
kandennti
Hello everyone. It will be helpful if you can tell me.
I am testing a script(addButtonDefinition) with two SelectionCommandInput.
The desired method is to enable the OK button only when two SelectionCommandInputs are selected, and to disable the button otherwise.
I understand that you can control the OK button with the areInputsValid property of the ValidateInputsEventArgs object.
However, the firing of ValidateInputsEvent is the timing when two SelectionCommandInputs are selected.
In the following code, if one is selected, the OK button will be enabled and the ValidateInputsEvent will not occur, so the OK button cannot be controlled. How should I do it?
Thanks in advance.
# python script
import adsk.core, adsk.fusion, traceback
_commandId = 'ValidateInputs'
_input1ID = 'Selectioninput1'
_input2ID = 'Selectioninput2'
_handlers = []
_app = None
_ui = None
class CommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            adsk.terminate()
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class ValidateInputHandler(adsk.core.ValidateInputsEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.ValidateInputsEventArgs.cast(args)
            inputs = args.inputs
            i1 :adsk.core.SelectionCommandInput = inputs.itemById(_input1ID)
            i2 :adsk.core.SelectionCommandInput = inputs.itemById(_input2ID)
            if i1.selectionCount > 0 and i2.selectionCount > 0:
                eventArgs.areInputsValid = True
            else:
                eventArgs.areInputsValid = False
            _ui.messageBox('call ValidateInputs')
        except:
            if _ui:
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            onDestroy = CommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onValidateInput = ValidateInputHandler()
            cmd.validateInputs.add(onValidateInput)
            _handlers.append(onValidateInput)
            inputs = cmd.commandInputs
            i1 = inputs.addSelectionInput(_input1ID, _input1ID,  _input1ID)
            i1.setSelectionLimits(1,1)
            i2 = inputs.addSelectionInput(_input2ID, _input2ID,  _input2ID)
            i2.setSelectionLimits(1,1)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDefs = _ui.commandDefinitions
        cmdDef = cmdDefs.itemById(_commandId)
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = cmdDefs.addButtonDefinition(_commandId, _commandId, _commandId)
        onCmdCreated = CommandCreatedHandler()
        cmdDef.commandCreated.add(onCmdCreated)
        _handlers.append(onCmdCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
kandennti
That's the way I came up.
・During the command activate event, two SelectionCommandInputs are forcibly selected and a ValidateInput event is generated.
・During the ValidateInput event, assign the generated ValidateInputsEventArgs to a variable with a large scope.
・ Empty two SelectionCommandInput.
・ Check the condition during the InputChange event and enable / disable the OK button.
I thought this would work, but I couldn't.
# python script
_handlers = []
_app = None
_ui = None
_valiIptEvtArgs = adsk.core.ValidateInputsEventArgs.cast(None)
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        global _valiIptEvtArgs
        if _valiIptEvtArgs is not None:
            return
        try:
            _valiIptEvtArgs = adsk.core.ValidateInputsEventArgs.cast(args)
        except:
            if _ui:
class InputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        if _valiIptEvtArgs is None:
            return
        try:
                _valiIptEvtArgs.areInputsValid = True
            else:
                _valiIptEvtArgs.areInputsValid = False
            _ui.messageBox('InputChangedHandler')
        except:
            if _ui:
class ActivateHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
            return
        try:
            inputs = args.command.commandInputs
            i1 = inputs.itemById(_input1ID)
            i2 = inputs.itemById(_input2ID)
            root = _app.activeProduct.rootComponent
            i1.addSelection(root.xYConstructionPlane)
            i2.addSelection(root.yZConstructionPlane)
            # call ValidateInput
            i1.clearSelection()
            i2.clearSelection()
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            onActivate = ActivateHandler()
            cmd.activate.add(onActivate)
            _handlers.append(onActivate)
            onInputChanged = InputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef.execute()
    except:
        if _ui:
What I want to achieve is, for example, the state of a sweep command.
If you select a profile and no path is selected, the OK button is disabled.
When the command cannot be executed, it is natural that the OK button is disabled.
MichaelT_123
Hi, Kondennti-san,
I am not sure if I fully understand the issue (had only very short glimpse at the post),
but if you want OK button active for both scenarios:
1.)  Selectioninput1=selected and  Selectioninput2=selected
2.)  Selectioninput1=selected and  Selectioninput2=not_selected
consider dynamically switch between as required:
Selectioninput2.setSelectionLimits(1,1) <==> Selectioninput2.setSelectionLimits(0)
Regards
MichaelT
MichaelT
kandennti
Thank you @MichaelT_123 .
By setting to setSelectionLimits (0), we found that ValidateInput event occurs frequently. It seems we can solve it.
I did not understand the timing of firing the ValidateInput event at all. . .
(Even if you click on nothing, it will fire)
