Offset body face with script ?
michelmarroche
michelmarroche
Hello, I have a question, can you make an offset to the face of a body with a script?
Thank you
michelmarroche
Hi @kandennti, I've seen that sample, but it's not what I'm looking for.. I need to make an offset of an existing body object, just like I would do from the mods menu with the offset face option, or with press/pull new offset ..
I have performed other operations from scripts such as extrude, shell, etc., but I cannot perform an offset to the same body
Does this function currently exist?
BrianEkins
That is an OffsetFacesFeature; currently, the API does not support its creation.
Brian Ekins
michelmarroche
Hello Brian !
Thanks for your answer ..
There is no other way to do it ? e.g. with Press/Pull ?
Let's say you can't implement that function from a script?
You have a lot of experience with script programming, I am automating the creation of a drawer from a box body, and there I perform a series of operations until I reach the drawer with its parts and modifications, I do it manually with functions of split body, shell, offset face and combine... with this I achieve the drawer
Now I would like to do this from a script..
Do you recommend replacing the offset function with another method other than extruding positive and negative? I have tested it by applying the operations of "JoinFeatureOperation" and "CutFeatureOperation"..
Thank you
BrianEkins
It is possible to extrude a planar face and if you use the "Join" operation would result in the same geometry as an offset in many cases.
Brian Ekins
michelmarroche
Hi Brian, thank you.
I'll follow your advice and see what I can do.
