Offset Automation (Python?)
doorpoo2
Observer Observer
doorpoo2
Observer
Observer
Hello all,
I have what I hope is a pretty simple question... I have to create multiple offsets of a sketch that is created from an SVG of a text.
-.375
-.3
-.1
-.075
-.275
Which is then repeated for every single letter. Is there away to automate this using the script feature? I looked at the offset tutorial, but it uses a sketch it creates, and I am not sure how to use a sketch that I have already. (Maybe a selected sketch or something like that)
Thanks!
kandennti
Hi @doorpoo2 .
I made a script.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Sketch Curve'
        selFilter: str = 'SketchCurves'
        sel: core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        sktCrv: fusion.SketchCurve = sel.entity
        distanceList = [
            0.375,
            0.3,
            0.1,
            0.075,
        exec_multiple_offsets(sktCrv, distanceList)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exec_multiple_offsets(
    sktCrv: fusion.SketchCurve,
    distanceList: list) -> None:
    skt: fusion.Sketch = sktCrv.parentSketch
    des: fusion.Design = skt.parentComponent.parentDesign
    unitmgr: core.UnitsManager = des.unitsManager
    ratio = unitmgr.convert(
        1,
        unitmgr.defaultLengthUnits,
        unitmgr.internalUnits,
    distLst = [d * ratio for d in distanceList]
    curves = skt.findConnectedCurves(sktCrv)
    dirPoint = adsk.core.Point3D.create(10000000, 10000000, 0)
    skt.isComputeDeferred = True
    for dist in distLst:
            skt.offset(curves, dirPoint, dist)
    skt.isComputeDeferred = False
def selectEnt(
        msg: str,
        filterStr: str) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
It works like this.
I haven't figured out how to use it, but if it were me, I would avoid making complex sketches and think about making offset bodies.
doorpoo2
Observer
Observer
@kandennti
That worked perfectly! Thank you soooo much! What a huge time saver.
