I wrote a quick test and cannot reproduce the problem you described. I went back and looked closer at your code and the problem isn't what you think it is. The problem is line 13. The include method returns an ObjectCollection that, in this case, returns a SketchPoint. In line 13, you're attempting to cast the SketchPoint to a Point3D object. That will fail, and the cast function will return None as a result. If you change line 13 to this, I believe it will work.
p = adsk.fusion.SketchPoint.cast(pnt)
And, since I already wrote it, here's the test case I created. I learned a couple of things. First is that if I used an ObjectCollection to do the include, the results weren't necessarily in the same order as the input. I don't think this is a bug, but is just the behavior you need to be aware of. As a result, I included them one at a time, which you were already doing. The other thing I learned is that the creation of the spline uses the input sketch points to get the coordinates, but does not associate the spline with the input points. I had to create a coincident point between the included points and the spline points. The code below does this.
def run(context):
app = adsk.core.Application.get()
ui = app.userInterface
try:
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
des: adsk.fusion.Design = doc.products.itemByProductType('DesignProductType')
root = des.rootComponent
# Create several construction planes with a sketch on each one.
constPlanes = root.constructionPlanes
planeInput = constPlanes.createInput()
planeInput.setByOffset(root.xYConstructionPlane, adsk.core.ValueInput.createByReal(5))
plane1 = constPlanes.add(planeInput)
s1 = root.sketches.add(plane1)
planeInput.setByOffset(root.xYConstructionPlane, adsk.core.ValueInput.createByReal(10))
plane2 = constPlanes.add(planeInput)
s2 = root.sketches.add(plane2)
planeInput.setByOffset(root.xYConstructionPlane, adsk.core.ValueInput.createByReal(15))
plane3 = constPlanes.add(planeInput)
s3 = root.sketches.add(plane3)
planeInput.setByOffset(root.xYConstructionPlane, adsk.core.ValueInput.createByReal(20))
plane4 = constPlanes.add(planeInput)
s4 = root.sketches.add(plane4)
# Create a point on each plane.
pointsOnPlanes = []
p1 = s1.sketchPoints.add(adsk.core.Point3D.create(5,0,1))
pointsOnPlanes.append(p1)
p2 = s2.sketchPoints.add(adsk.core.Point3D.create(5,6,1))
pointsOnPlanes.append(p2)
p3 = s3.sketchPoints.add(adsk.core.Point3D.create(10,8,1))
pointsOnPlanes.append(p3)
p4 = s4.sketchPoints.add(adsk.core.Point3D.create(12,15,1))
pointsOnPlanes.append(p4)
# Include the points into the result sketch. They are included
# one at a time to be able to match the result to the input.
resultSk: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
pointsInResult = []
for point in pointsOnPlanes:
result = resultSk.include(point)
pointsInResult.append(result[0])
# create the spline using the points.
fitPoints = adsk.core.ObjectCollection.create()
for point in pointsInResult:
fitPoints.add(point)
crv = resultSk.sketchCurves.sketchFittedSplines.add(fitPoints)
# Add coincident constraints between the fit points and the sketch points.
geomConsts = resultSk.geometricConstraints
for i in range(4):
geomConsts.addCoincident(pointsInResult[i], crv.fitPoints[i])
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian EkinsInventor and Fusion 360 API Expert
Website/Blog:
https://EkinsSolutions.com
