No respond with EDIT scripts in windows10
After the API environment updated to VScode,  I followed the introduction install VScode and Autodesk Fusion 360 Post Processor Utility.
But when I click to edit, nothing happened!  VScode was also don't have any reaction.
only this window jumped out when I first click.
My laptop is Windows10, the spyder was running well.
And I also find my script can't work now, but in my old computer's Fusion(haven't update) still could work.
Nilesh.Mohite
Hi @Anonymous ,
It is issue with latest python extension installed in VSCode.
You need to downgrade the ms-python extension from VScode to lower version 2019.9.34911.
Please refer to the following similar issue.
API debugger doesn't work after Oct 2019 update
Solutions provided by @goyals will work for you. Go to Solution.
The window you are seeing is fusion checks for the extension if it not there it will try to install latest extension.
Let us know if you need more help.
Nilesh Mohite
LinkedIn
If my answer helped you, please use  ACCEPT SOLUTION .
Also be generous with Likes!  Thank you and enjoy!
It's worked!
Thank you a lot!
