No module named 'adsk'
Hi There!!!
I'm trying to use Python with visual studio, but I get I get the error:
ModuleNotFoundError: No module named 'adsk'
I tested the troubleshooting mention here:
Python cannot import Adsk.core module
import sys
sys.path.append("C:/Users/xx/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Python/defs")
import adsk.core, adsk.fusion, adsk.cam, traceback
But I just keep getting the same error.
Looking forward for your advice,
kandennti
Hi @Anonymous .
Try it in VS Code instead of visual studio.
Yes, there are warnings, but I don't think it will affect execution or development.
Sry I mean Visual studio code.
Well you are right, but it takes few more clicks and moves.
Idealy I should be able to press run  on VSC and see the changes on F360.
Do you know is this is possible?
