New F360 Update
New F360 Update
MichaelT_123
Advisor Advisor
New F360 Update
MichaelT_123
Hi Fellows,
After the last update, I can't access VSCode editor even by trying to open the sample script and rebooting twice.
I can open VSC externally. It starts with the files from my last (before the update) session.
Am I alone in this?
Signature of VSC is:
Version: 1.49.0 (user setup)
Commit: e790b931385d72cf5669fcefc51cdf65990efa5d
Date: 2020-09-10T13:22:08.892Z
Electron: 9.2.1
Chrome: 83.0.4103.122
Node.js: 12.14.1
V8: 8.3.110.13-electron.0
OS: Windows_NT x64 10.0.18362
Regards
MichaelT
MichaelT
Rushikesh.kadam
@MichaelT_123 can you try out solutions mentioned in https://forums.autodesk.com/t5/fusion-360-api-and-scripts/spyder-trouble/m-p/9674618#M10900 and https://forums.autodesk.com/t5/fusion-360-support/can-t-edit-f360-scripts-vcs-does-not-open/m-p/9745...
Rushikesh Kadam
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button (or both)
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
MichaelT_123
Hi Mr RushikeshKadam,
Thank you for the fast response.
I was on recommended 2019.9.34911 version of Python extension. It did not work, but after the suggestion by Mr Jerome Briot, everything went to normal smoothly ( many kisses Mr Briot 😚).
For others reading the post:
It seems to be safe to upgrade to 2020.6.91350.
Regards
MichaelT
MichaelT
MichaelT_123
The solution has been wrongly attributed to me. It should be shared by real contributors:
Mr RushikeshKadam and Mr Jerome Briot instead!
MichaelT
