My first add-in: Visual Styles
pawelzwronek
Message 1 of 100
pawelzwronek
Hello everybody.
Today i want to share with you my first addin I have created couple days ago. Because my previous idea of "Customized bottom navigation bar" gained whole 10 kudos i decided to write some kind of substitute of this idea. Fell free to download and test it because it's free 🙂 Below screenshot and link to appstore.
MAC and PC
What it does?
Simply a couple of buttons to quickly change visual style of active viewport.
Want to contribute?
Visit github.com/pawelzwronek/fusion360-VisualStyles
P.S. If you like it (or not) and use it please leave a comment in App Store to give me motivation to make it better or to write next one.
Replies (99)
Message 41 of 100
JetForMe
That still isn't working for me. Is there a way to get diagnostic logs so I can see what happens as it enumerates the plug-ins directory?
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
Message 42 of 100
luca.giorcelli
Do you want to try the rough way, downloading and using my own bundle file? If you want I can make it available via dropbox (hoping that this is not a problem for @pawelzwronek )
Message 43 of 100
luca.giorcelli
[Unwanted duplicate]
Message 44 of 100
pawelzwronek
Maybe try to manually install it with this steps:
Extract somewhere attached file VisualStyles.bundle.mac.zip or VisualStyles.bundle.win.zip1.png
  1. Add-ins
  2. Add-Ins tab
  3. RMB on VisualStyles if any exists (On mac there is only on mouse button, right? Then maybe hold CMD on kayboard )
  4. Remove
  5. Green plus - add existing add-in. Choose extracted VisualStyles.py
  6. Select VisualStyles
  7. Click 'Run'
  8. Select 'Run on Startup' checkbox.
Does it worked?
Message 45 of 100
JetForMe
Yes! That worked! It took a LONG time to load, locking up the UI until it figured itself out. It also asked me in the middle of that about storing preferences in the cloud (I should have answered No). but now it's all set up, I'm able to adjust which visual styles are on display, Thank you!
Message 46 of 100
GMDCNC
In the latest version of Fusion, and the latest version of Visual Styles, on Mac, Fusion 360 locks up if I try to change which visual styles are enabled. I get a beach ball within Fusion and I have to force quit the app. I'd post a screencast of it, but screencast locks up along with Fusion.
Message 47 of 100
JetForMe
Mine did that, too, but it eventually came back. Took a long time (10 min?). Something about network prefs, I think.
Message 48 of 100
GMDCNC
I walked away for 3 hours and it was still frozen when I got back.
Message 49 of 100
JetForMe
Oh, bummer. I must've gotten lucky.
Message 50 of 100
I have this installed and it's awesome.
I only have one issue and i'm hoping it's an easy fix.
Every time Fusion does an update I have to set my preferences again 😞 minor issue I know but just annoying.
TIA
Stephen,
Message 51 of 100
daniel_lyall
Just hit no it still works fine after fusion gets updated.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 52 of 100
pawelzwronek
Yep, I should've put the configuration file in the roaming folder. I didn't know Fusion is changing folder after every update. Will fix that soon.
Message 53 of 100
pawelzwronek
Version 1.2.1 with configuration moved to roaming directory is now live Win64 and MacOS
Message 54 of 100
Patofoto
Thanks everyone for all your suggestions. I've tried all and I can't get the addin working. It shows in my addin window but it won't run.
MacBook Pro
macOS High Sierra 10.13.1
Fusion 360 2.0.3706
Anyone else still in my same predicament?. Any suggestions?. Thanks again. One of my most used addins and I really miss it!!!
Message 55 of 100
luca.giorcelli
Mac installer may not work properly, as it happened to me. But finally I've solved my problem.
Please check what you have in the library after plugin installation, this is the path: ~/Library/Application Support/Autodesk/ApplicationPlugins
If you have an alias file (icon has a small black arrow) as in the image below, then it will not work.
You need to have the actual bundle file, as in the image below.
If you have the "alias" problem, as I had, then you can solve your problem following these instructions:
  1. Unpack VisualStyles-macos.pkg, I've used unpkg 4.5 available for free here: https://www.macupdate.com/app/mac/16357/unpkg
  2. Copy VisualStyles.bundle in this directory ~/Library/Application Support/Autodesk/ApplicationPlugins
Message 56 of 100
Patofoto
Thank you Luca for all your help. I do have the actual plugin and not the alias. Don't know what is going on. Could it be a conflict with another plugin?.
Message 57 of 100
luca.giorcelli
Sorry, I've no idea. I've attached my bundle (zipped). My finder sizes it 826 Kb, instead of 827 Kb sized by your finder, may be it is different. If you want you can try it.
Message 58 of 100
Patofoto
It worked!!!. Thank you Luca. Interesting finding. Wonder what is going on. Much appreciated.
Message 59 of 100
luca.giorcelli
I'm happy.
PS: your rolleiflex is great. I've done photos for 20 years using my tessar 3.5 rolleiflex. Insuperable for street photograpy.
Message 60 of 100
Patofoto
Thank you for your help. I shoot mostly medium format and my Hasselblad is my go-to camera. My favorite street camera is my Mamiya 6. Can't seem to save preferences as I'm getting the choose dialogue. Web takes forever to save. Reading the other posts to see if I can find a solution.
