My AddIn cannot run on another computer
xusho
Autodesk Autodesk
xusho
I have created an addin in Fusion 360.
FindIncorrectBosses.dll is the entry, it calls mfpath.dll. Below is the contents in the folder:
The program is supposed to create an icon on QAT at the beginning.
It can work on my machines. But when copying to a laptop of someone else, it could not start.
The laptop has Fusion 360 and VS2017 installed.
Please advise:
1. Which files should be copied? Does it need to include *.cpp file?
2. Is it possible to debug?
Shoudong Xu
Shoudong Xu
Autodesk Moldflow Meshing
Shoudong.Xu@autodesk.com
xusho
More info:
The addin is in C++. It was created in a folder under the default location: C:\Users\xusho\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\
Shoudong Xu
