MS Code - Python extension exception
balunist
balunist
Running the latest Python extension I consistently get the following exception.   Has anyone else experienced this?
No breakpoints are set and this occurs shortly after a successful startup of my app.
Thanks in advance!
Exception in thread ptvsd.Server: Traceback (most recent call last): File "/Users/<userid>/.vscode/extensions/ms-python.python-2020.6.90262/pythonFiles/lib/python/old_ptvsd/pt...", line 269, in process_one_message msg = self.__message.pop(0) IndexError: pop from empty list
Rushikesh.kadam
Hi @balunist , this issues looks to be similar to https://forums.autodesk.com/t5/fusion-360-api-and-scripts/vs-code-upgrade-to-the-latest-python-exten..., can you try if the mentioned solution works for you also?
Rushikesh Kadam.
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button below (or both).
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
balunist
I deleted the extension as described and allowed Fusion to install by invoking debug.   They installed the latest version.   I included a fusion restart before and after.    I’m still seeing the same exception pop up after seeing my app successfully start.
So no change occurred and it did not fix the problem.
