Moving text within a sketch breaks the world
import adsk.core, adsk.fusion, traceback
def Point3D(x, y):
  return adsk.core.Point3D.create(x, y, 0)
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    des = adsk.fusion.Design.cast(app.activeProduct)
    root = des.rootComponent
    sketch = root.sketches.add(root.xYConstructionPlane)
    msg = (
        'this is my string it might be long\n'
        'and multi lined.\n\n'
        'I would like to be able to center it\n'
        'in the sketch space.')
    text_input = sketch.sketchTexts.createInput(msg, 0.25, Point3D(1, 1))
    text_input.fontName = 'Consolas'
    txt = sketch.sketchTexts.add(text_input)
    text_p = txt.boundingBox.maxPoint.copy()
    text_p.x = -(text_p.x - 1) / 2
    text_p.y = -(text_p.y - 1) / 2
    text_p.z = 0
    txt.position = text_p
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
This code breaks the drawing it is run in. Documentation states that text position can be SET but when you do set it the UCS icon vanishes and it's impossible to zoom/pan  to anything.
marshaltu
Thank you for reporting the issue to us. UP-36437 has been logged in our internal system to track it.
Marshal
Marshal Tu
Fusion Developer
