Moving text within a sketch breaks the world
02:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
import adsk.core, adsk.fusion, traceback
def Point3D(x, y):
return adsk.core.Point3D.create(x, y, 0)
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
des = adsk.fusion.Design.cast(app.activeProduct)
root = des.rootComponent
sketch = root.sketches.add(root.xYConstructionPlane)
msg = (
'this is my string it might be long\n'
'and multi lined.\n\n'
'I would like to be able to center it\n'
'in the sketch space.')
text_input = sketch.sketchTexts.createInput(msg, 0.25, Point3D(1, 1))
text_input.fontName = 'Consolas'
txt = sketch.sketchTexts.add(text_input)
text_p = txt.boundingBox.maxPoint.copy()
text_p.x = -(text_p.x - 1) / 2
text_p.y = -(text_p.y - 1) / 2
text_p.z = 0
txt.position = text_p
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))This code breaks the drawing it is run in. Documentation states that text position can be SET but when you do set it the UCS icon vanishes and it's impossible to zoom/pan to anything.
