Model parameters, expressions and values.
brad.bylls
brad.bylls
Using the below code to create an extrusion.
I am able to change the top name(yellow) of the parameter.
What I would like to do is change the sub-name(blue) and the 'Name'(green)
Lastly I would like to change the expression(red) to be the same as the value(in)
Because it is a TwoSidesExtent, I am at a loss as to how to do it.
# Create the head clearance
        cutHeadSketch = sketches.add(xyPlane)
        cutHeadCircle = cutHeadSketch.sketchCurves.sketchCircles.addByCenterRadius(center, numBoltCboreDiam/2)
        cutHeadSketch.sketchDimensions.addDiameterDimension(cutHeadCircle, adsk.core.Point3D.create(-110))
        cutHeadSketch.name = 'Head Clearance Sketch'
        cutHeadProf = cutHeadSketch.profiles[0]
        cutHeadExtInput = extrudes.createInput(cutHeadProf, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        distance1 = adsk.fusion.DistanceExtentDefinition.create(adsk.core.ValueInput.createByReal(numBoltClearanceLength - numBoltBodyLength))
        distance2 = adsk.fusion.DistanceExtentDefinition.create(adsk.core.ValueInput.createByReal(numBoltTravelLength))
        deg0 = adsk.core.ValueInput.createByString("0 deg")
        cutHeadExtInput.setTwoSidesExtent(distance1, distance2, deg0, deg0)
        cutHeadExt = extrudes.add(cutHeadExtInput)
        cutHeadExt.name = 'Head Clearance Extrude'
Brad Bylls
kandennti
Hi @brad.bylls .
I don't think sub-name (blue) can be changed.
(I couldn't do it even with GUI)
'Name' (green) can be changed by getting the model parameters.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-86e451c2-785f-4cdf-97c9-ecba4882c8d1
Wouldn't expression (red) be'in'by using createByString?
        # Head Clearance Sketch
        cutHeadCircle_Dia = cutHeadSketch.sketchDimensions.addDiameterDimension(cutHeadCircle, adsk.core.Point3D.create(-1, 1, 0))
        cutHeadCircle_Dia.parameter.name = 'BoltCboreDiam'# parameter rename
        # Head Clearance Extrude
            adsk.core.ValueInput.createByString('{} in'.format(numBoltClearanceLength - numBoltBodyLength)))# use createByString
            adsk.core.ValueInput.createByString('{} in'.format(numBoltTravelLength)))# use createByString
        cutHeadExt.extentOne.distance.name = 'Head_Length'# parameter rename
        cutHeadExt.extentTwo.distance.name = 'Travel_Length'# parameter rename
        cutHeadExt.taperAngleOne.name = 'Head_Angle'# parameter rename
        cutHeadExt.taperAngleTwo.name = 'Travel_Angle'# parameter rename
brad.bylls
Thank you for the help.
It worked.
Brad Bylls
