Missing extent parameter for FilletFeature / ChamferFeature / OffsetFacesFeature?
amandaghassaeiS8KA2
amandaghassaeiS8KA2
I'm working on a python script for creating an animation of my design's Design History Timeline and am having trouble figuring out how to get ahold of the extent property (or similar) for FilletFeature, ChamferFeature, and OffsetFacesFeature.  Their API references are below:
Fillet - https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9f6de809-6e53-4667-bedb-9e95600411e9
Chamfer - https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7a005e53-0664-479c-9f6a-6146709ca1ef
OffsetFaces - https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-5FF19D49-8553-4F36-9C7F-8199B2A71933
Other features (e.g. ExtrudeFeature, RevolveFeature) have extent, extentOne/extentTwo, or extentDefinition properties exposed.  Is this something incomplete in the API or am I thinking about this wrong?
Thanks!
Amanda
goyals
Not sure I understood what do you mean by extent property on Fillet and Chamfer feature. There is no such option exist in UI hence not exposed through API as well. Please provide some more details on what you are trying. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
amandaghassaeiS8KA2
For Fillet, how do I get/set the radius?  For Chamfer and OffsetFace how do I get/set the "distance"?
goyals
Please take a look at this sample showing how to modify fillet radius value
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a4dc7230-60f3-11e5-a4e9-989096c56ffe
Same way you can handle Chamfer and Offset by using corresponding methods.
Shyam Goyal
amandaghassaeiS8KA2
ok that makes sense, thanks for the info!
