Here's a quick function I whipped up that seems to work for me, on a simple cylinder that I exported and then reimported as a mesh, and then converted to brep. This may require the document to be in direct mode. I didn't try it in parametric mode.
import traceback
import adsk.core
import adsk.fusion
def run(context):
try:
root = adsk.core.Application.get().activeProduct.rootComponent # type: adsk.fusion.Component
merge_planar_faces(root.bRepBodies[0])
except Exception:
print(traceback.format_exc())
def collection_of(collection):
object_collection = adsk.core.ObjectCollection.create()
for obj in collection:
object_collection.add(obj)
return object_collection
def merge_planar_faces(body: adsk.fusion.BRepBody):
first_temp_surface = None
temp_unioned_surface = None
brep = adsk.fusion.TemporaryBRepManager.get()
for face in body.faces:
# convert the face to a temporary BRepBody
temp_surface = brep.copy(face)
if first_temp_surface is None:
# We need at least two faces to use a stitch feature, so keep a lone copy of the first face
first_temp_surface = temp_surface
elif temp_unioned_surface is None:
# All the other faces get unioned into a single temporary BRepBody
temp_unioned_surface = temp_surface
else:
# Adds this face to the temporary BRepBody that contains all the other faces
brep.booleanOperation(temp_unioned_surface, temp_surface, adsk.fusion.BooleanTypes.UnionBooleanType)
# Now stitch the first face, and all the remaining faces together, into a single solid body
# This has the side effect of merging any coplanar faces that share an edge
surfaces = [body.parentComponent.bRepBodies.add(first_temp_surface),
body.parentComponent.bRepBodies.add(temp_unioned_surface)]
stitch_input = body.parentComponent.features.stitchFeatures.createInput(
collection_of(surfaces),
adsk.core.ValueInput.createByReal(.01),
adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
body.parentComponent.features.stitchFeatures.add(stitch_input)
body.deleteMe()
