MeasureManager discrepancy
MichaelT_123
Advisor Advisor
MichaelT_123
Hi TF360,
Just a small problem,... not life threatening though.
As per documentation:
MeasureResults = measureManager_var.measureMinimumDistance(geometryOne, geometryTwo)
MeasureResults object has two ((relevant in the discussion) properties.
positionOneFor a distance measurement, this is the point on the first entity where the measurement was made from. For an angle measurement this is one of the three points defining the angle.
positionTwoFor a distance measurement, this is the point on the second entity where the measurement was made to. For an angle measurement this is one of the three points defining the angle.
As per the descriptions, one would expect that positionOne  refers to the first argument of measureMinimumDistance() function. It seems to be not the case.
Please find attached basic test files.
#Author-MT
#Description-MeasureManager problem
MeasureResults A MeasureResults object that contains the distance and the two points on the geometry that the distance that was measured between them in centimeters.
Name        Type  Description
geometryOne Base  The first geometry to measure from. This can be an Occurrence, any B-Rep entity (BRepBody, BRepFace, BRepEdge, BRepVertex, etc.), any construction geometry, any sketch entities, and any temporary 3D geometry (Cylinder, Plane, Line3D, etc.).
geometryTwo Base  The second geometry to measure to. This can be an Occurrence, any B-Rep entity (BRepBody, BRepFace, BRepEdge, BRepVertex, etc.), any construction geometry, any sketch entities, and any temporary 3D geometry (Cylinder, Plane, Line3D, etc.).
MeasureResults Object
positionOne       For a distance measurement, this is the point on the first entity where the measurement was made from. For an angle measurement this is one of the three points defining the angle.
positionThree     This point is only used for angle measurements and is one of the three points defining the angle.
positionTwo       For a distance measurement, this is the point on the second entity where the measurement was made to. For an angle measurement this is one of the three points defining the angle.
value             The measurement value. If the measurement is a distance this value will be in centimeters. If it's an angle then it will be in radians.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app  = adsk.core.Application.get()
        ui   = app.userInterface
        des  = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        testPoint = root.originConstructionPoint.geometry
        testFace  = root.bRepBodies.item(0)
        measureResu = app.measureManager.measureMinimumDistance( testPoint, testFace )
        minDistance = measureResu.value
        positionOne = measureResu.positionOne
        positionTwo = measureResu.positionTwo
        msg  = 'minDistance = {:g}\n'.format(minDistance)
        msg += 'testPoint   = <{:g},{:g},{:g}>\n'.format(testPoint.x, testPoint.y, testPoint.y)
        msg += 'positionOne = <{:g},{:g},{:g}>\n'.format(positionOne.x, positionOne.y, positionOne.y)
        msg += 'positionTwo = <{:g},{:g},{:g}>\n'.format(positionTwo.x, positionTwo.y, positionTwo.y)
        msg += '\n'
        msg += 'testPoint.isEqualTo(positionOne) = {:s}\n' .format(str(testPoint.isEqualTo(positionOne)))
        msg += 'testPoint.isEqualTo(positionTwo) = {:s}\n' .format(str(testPoint.isEqualTo(positionTwo)))
        ui.messageBox(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Regards
MichaelT
MichaelT
kandennti
Hi @MichaelT_123 .
I tried it here, and the result was the same.
        measureResu = app.measureManager.measureMinimumDistance(testFace, testPoint)
I will remember that "the order of positionOne and positionTwo is not guaranteed”.
Thanks.
