Master / Slave Automatic Updates
I'm looking to see if there are any options to speed my example below.
If you look at the sketch below;
On electrical drawings if i have to change Pair 7 (My master) i have 5 other variables to change.
  • Terminal Numbers
  • Pair
  • Cable Colours
Are there any coding / block options out there where if i change my master pair number, my 5 slaves will change to pre determined valves.
ekinsb
You're using Fusion for electrical drawings?  Can you explain a little more about what you're doing now?
Brian Ekins
Mod the Machine blog
I'm not using Autocad fusion, standard Autocad 2015.
I think that i will need to have one of the electrical package add on to carry out what i want to do.
I mark up at times electrical drawings. Alot of the same information is constantly changed depending on one or two variable.
e.g.
Pair 1 would change 4 / 5 no. variables
Pair 2 would change the same 4/5 variable to different values
Pair 3 etc. etc.
If a cable no changes this no. has to be changed in 4 / 5 different locations.
What im looking for is if the cable no. is changed in one place the other 4 / 5 places where it needs to be changed can be automatically updated.
In theory a master is changing slave variable to set / pre determined values.
Many Thanks,
Ruaidhri
ekinsb
This forum is for Fusion API questions.  I don't think there are any AutoCAD experts monitoring this.  I suggest you re-post your question in an AutoCAD specific forum.
Brian Ekins
