make user selections dynamically visible on user selections
joergDVRXK
joergDVRXK
Hi, i would like to make the available selections in the user interface dynamic on selections, for example on activation of a checkbutton. Is there a sample code or tutorial on how to do that?
Best regards
J.
Jorge_Jaramillo
Here you have an example you can use to dynamically change the selection filter:
COMMAND_ID = 'commandTests'
T02_SELECTOR_COMMAND_ID = 'selector'
T02_SELECTION_COMMAND_ID = 'selection'
T02_SELECTORS = ["SketchPoints", "SketchLines", "Bodies", "Faces"]
_handlers = []
class CommandTestsDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            cmdDef = ui.commandDefinitions.itemById(COMMAND_ID)
            if cmdDef:
                cmdDef.deleteMe()
            adsk.terminate()
        except:
            app.log('Failed:\n{}'.format(traceback.format_exc()))
class CommandTest02_DynamicSelInputChanged(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.InputChangedEventArgs):
        try:
            if args.input.name == T02_SELECTOR_COMMAND_ID:
                selr: adsk.core.RadioButtonGroupCommandInput = args.inputs.itemById(T02_SELECTOR_COMMAND_ID)
                sels: adsk.core.SelectionCommandInput = args.inputs.itemById(T02_SELECTION_COMMAND_ID)
                sels.selectionFilters = [selr.selectedItem.name]
                sels.clearSelection() # Comment this line to kept previous selections
        except:
class CommandTest02_DynamicSelExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
        try:
            sels: adsk.core.SelectionCommandInput = args.command.commandInputs.itemById(T02_SELECTION_COMMAND_ID)
            for i in range(sels.selectionCount):
                app.log(f'   {i} : {sels.selection(i).entity}')
        except:
class CommandTest02_DynamicSelCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        global _handlers
        try:
            onDestroy = CommandTestsDestroyHandler()
            args.command.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = CommandTest02_DynamicSelExecuteHandler()
            args.command.execute.add(onExecute)
            _handlers.append(onExecute)
            onInput = CommandTest02_DynamicSelInputChanged()
            args.command.inputChanged.add(onInput)
            _handlers.append(onInput)
            inputs = args.command.commandInputs
            selr: adsk.core.RadioButtonGroupCommandInput = \
                inputs.addRadioButtonGroupCommandInput(T02_SELECTOR_COMMAND_ID, T02_SELECTOR_COMMAND_ID)
            for sel in T02_SELECTORS:
                selr.listItems.add(sel, sel == T02_SELECTORS[0])
            sels = inputs.addSelectionInput(T02_SELECTION_COMMAND_ID, T02_SELECTION_COMMAND_ID, T02_SELECTION_COMMAND_ID)
            sels.selectionFilters = [T02_SELECTORS[0]]
            sels.setSelectionLimits(0) #unlimited selections
        except:
def commandTests():
    global _handlers
    try:
        if not cmdDef:
            cmdDef = ui.commandDefinitions.addButtonDefinition(COMMAND_ID, 'Commands Tests', 'Commands Tests')
        onCommandCreated = CommandTest02_DynamicSelCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
I hope it can help.
Jorge Jaramillo
joergDVRXK
Hi Jorge, thank you for the code! That helps a lot. Is there also a possibility to create new input fields depending on the selection with the radiobutton or by a checkbox?
In my skript 3 splines must be selected and a plane from the origin for orientation.
Then there are two ways to choose from to produce eggshaped spans. I would like the "subchoices" only to appear by selection (check- or radiobutton):
a) equal distances (requires the fields for the distance, the checkbox if a first span should be set at 0 and the number of spans)
b) manually set distances for each span from the origin (i managed that by a textinput with csv input but actually would like to have one field and a button to create more distanceInput fields).
 best regards Jörg
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
import math as m
# Global set of event handlers to keep them referenced for the duration of the command
handlers = []
ui = None
app = adsk.core.Application.get()
if app:
    ui  = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
root = design.rootComponent
sketches = root.sketches
planes = root.constructionPlanes
l_xmax = []
l_xmin = []
l_xmit = []
l_ymax = []
l_off = []
l_Plane = []
class SpanCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            command = args.firingEvent.sender
            inputs = command.commandInputs
            input1 = inputs[0];
            sel0 = input1.selection(0)
            input2 = inputs[1];
            sel1 = input2.selection(0)
            input3 = inputs[2];
            sel2 = input3.selection(0)
            input4 = inputs[3];     # number of points / 4
            input5 = inputs[4];    #plane
            sel3 = input5.selection(0)
            input6 = inputs[5]     # abstand
            input7 = inputs[6]      # number of spans
            input8 = inputs[7]
            input9 = inputs[8]    # weitere Spanten mit offsetwert angeben
            anzahl_span = float(input7.value)
            delta_span = float(input6.value)
            if input9.value != "":
                temp = input9.value
                temp = temp.split(";")
                temp = list(map(int, temp))
                for i in range(len(temp)):
                    l_off.append(float(temp[i]/10))
            if input8 == True:
                faktor = i
                anzahl_span -= 1
            for i in range(int(anzahl_span)):
                if input8.value == True:
                    faktor = i
                else:
                    faktor = i + 1
                temp = float(faktor * delta_span)
                l_off.append(temp)
            if sel3.entity == root.xYConstructionPlane:
                input_orientierung = "xY"
            elif sel3.entity == root.yZConstructionPlane:
                input_orientierung = "yZ"
            elif sel3.entity == root.xZConstructionPlane:
                input_orientierung = "xZ"
            spline_o = sel0.entity
            spline_u = sel1.entity
            spline_m = sel2.entity
            entities_o = []
            entities_u = []
            entities_m = []
            entities_o.append(spline_o) # sketch curve
            entities_u.append(spline_u)
            entities_m.append(spline_m)
            entities_all = []
            entities_all.append(spline_o)
            entities_all.append(spline_u)
            entities_all.append(spline_m)
            def intersection_ebene(offset_z, entities_o, entities_u, entities_m, input_orientierung):
                if input_orientierung == "xY":
                    offset_z = -float(offset_z)
                    sketch3d = sketches.add(root.xYConstructionPlane)
                elif input_orientierung == "yZ":
                    offset_z = float(offset_z)
                    sketch3d = sketches.add(root.yZConstructionPlane)
                elif input_orientierung == "xZ":
                    sketch3d = sketches.add(root.xZConstructionPlane)
                planeInput = planes.createInput()
                # Create three sketch points
                sketchPoints = sketch3d.sketchPoints
                positionOne = adsk.core.Point3D.create(0.0, 0.0, offset_z)
                sketchPointOne = sketchPoints.add(positionOne)
                positionTwo = adsk.core.Point3D.create(0, 10.0, offset_z)
                sketchPointTwo = sketchPoints.add(positionTwo)
                positionThree = adsk.core.Point3D.create(10.0, 10.0, offset_z)
                sketchPointThree = sketchPoints.add(positionThree)
                # Add construction plane by three points
                planeInput.setByThreePoints(sketchPointOne, sketchPointTwo, sketchPointThree)
                planes.add(planeInput)
                plane3d = planes[len(planes) - 1]
                #l_Plane.append(plane3d)
                plane3d.name="offset_3_points"
                sketch2o = sketches.add(plane3d)
                sketchEntities_o = sketch2o.intersectWithSketchPlane(entities_o)
                sketch2u = sketches.add(plane3d)
                sketchEntities_u = sketch2o.intersectWithSketchPlane(entities_u)
                sketchEntities_m = sketch2o.intersectWithSketchPlane(entities_m)
                # Get the value of the property.
                pt_o = []
                pt_u = []
                pt_m = []
                for po in sketchEntities_o:
                    if po.objectType == adsk.fusion.SketchPoint.classType():
                        temp = po.worldGeometry.asArray()
                        pt_o.append(temp[0])
                        pt_o.append(temp[1])
                        pt_o.append(temp[2])
                for pu in sketchEntities_u:
                        temp = pu.worldGeometry.asArray()
                        pt_u.append(temp[0])
                        pt_u.append(temp[1])
                        pt_u.append(temp[2])
                for pm in sketchEntities_m:
                        temp = pm.worldGeometry.asArray()
                        pt_m.append(temp[0])
                        pt_m.append(temp[1])
                        pt_m.append(temp[2])
                pt_o = list(map(float, pt_o))
                pt_u = list(map(float, pt_u))
                pt_m = list(map(float, pt_m))
                    xmax = 1 * pt_o[2]
                    xmin = 1 * pt_u[2]
                    xmit = 1 * pt_m[2]
                    ymax = 1 * pt_m[1]
                elif input_orientierung == "xY":
                    xmax = 1 * pt_o[1]
                    xmin = 1 * pt_u[1]
                    xmit = 1 * pt_m[1]
                    ymax = 1 * pt_m[0]
                    xmax = 1 * pt_o[2]
                    xmin = 1 * pt_u[2]
                    xmit = 1 * pt_m[2]
                    ymax = 1 * pt_m[0]
                else:
                    ui.messageBox("orientierung?")
                l_xmax.append(xmax)
                l_xmin.append(xmin)
                l_xmit.append(xmit)
                l_ymax.append(ymax)
                # to get the offset in the thired dimension right reference to the original plane of the sketch with the selected intersections
                ents = []
                for ent in sketchEntities_o:
                    ents.append(ent)
                for ent in sketchEntities_u:
                    ents.append(ent)
                for ent in sketchEntities_m:
                    ents.append(ent)
                sketch3 = ents[0].parentSketch
                sketch3.name="Sketch3"
                Plane = sketch3.referencePlane
                Plane = plane3d
                l_Plane.append(Plane)
                del ents
                letzter_sketch = len(sketches) - 1
                sketches[letzter_sketch].deleteMe()
                sketches[letzter_sketch - 1].deleteMe()
                sketches[letzter_sketch - 2].deleteMe()
                sketches[letzter_sketch - 3].deleteMe()
                letzte_ebene = len(planes) - 1
                planes[letzte_ebene].deleteMe()
            for i in range(len(l_off)):
                intersection_ebene(l_off[i], entities_o, entities_u, entities_m, input_orientierung)
            # execute the calculation programm with the user selected values
            span = Span()
                span.Execute(l_Plane[i], l_xmax[i], l_xmin[i], l_xmit[i], l_ymax[i], input4.value, l_off[i], input_orientierung);
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler that reacts to when the command is destroyed. This terminates the script.
class SpanCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # When the command is done, terminate the script
            # This will release all globals which will remove all event handlers
            adsk.terminate()
        except:
            if ui:
class Span:
    def Execute(self, Plane, xmax, xmin, xmit, ymax, anzahl_punkte_4, offset_z, input_orientierung):
        x_coord = [] # list of coordinates for spline
        y_coord = [] # list of coordinates for spline
        # multiply the input by 4 to get the number of points to be created
        anzahl_punkte = anzahl_punkte_4 * 4
        global sketches
        global planes
        try:
        except RuntimeError:
            ui.messageBox('You should select origin plane or construction plane.', 'Error')
            return
        points = adsk.core.ObjectCollection.create()
        # calculate parameters a, b, d from input coordinates
        a = 0.5 * abs(xmax - xmin)
        b = abs(ymax)
        # moved position off the circle midpoint M1 from (0, 0) bei (x_m1, 0)
        x_m1 = xmax - a
        d = -(xmit - x_m1)
        # calculation of the eggshape around the origin → will be moved later
        xwerte = [] # lists of the calculated values
        ywerte = []
        xwerte_offset = []
        # fritz huegel schaeffer calculation depending on the angle
        punkt = 0
        while punkt < anzahl_punkte + 1:  # first and last point identical for a closed spline
            kreisteiler = 360 / anzahl_punkte
            t = punkt * kreisteiler  # kreisteiler (example: divider of the circle by 5° angles results in 72 points)
            if t == 90:   # avoid errors from rounding at the points the spline cuts the splines from the fusselage shape. Use the original inputs.
                y2 = ymax
            elif t == 270:
                y2 = -ymax
            else:
                y2 = b * m.sin(m.radians(t))
            ywerte.append(y2)
            x1 = (m.sqrt((a ** 2) - (d ** 2) * ((m.sin(m.radians(t))) ** 2)) + d * m.cos(m.radians(t))) * m.cos(
                m.radians(t))
            xwerte.append(x1)
            punkt += 1
        # moving the x-values by comparing the calculated top around the origin with the top from the input data
        offset = xmax - xwerte[0]
        for w in range(len(xwerte)):
            x_new = xwerte[w] + offset
            xwerte_offset.append(x_new)
        k = len(xwerte) - 1
        l = int(0.5*k)
        xwerte_offset[0] = xmax
        xwerte_offset[k] = xmax
        xwerte_offset[l] = xmin
        for h in range(len(xwerte)):
            x_coord.append(ywerte[h])
            y_coord.append(xwerte_offset[h])
                for i in range(len(x_coord)):
                    point = adsk.core.Point3D.create(ywerte[i], xwerte_offset[i], -offset_z)
                    points.add(point)
                sketch3 = root.sketches.add(root.xYConstructionPlane)
                sketch3.sketchCurves.sketchFittedSplines.add(points)
                    point = adsk.core.Point3D.create(xwerte_offset[i], ywerte[i], offset_z)
                    points.add(point)
                sketch3 = root.sketches.add(root.yZConstructionPlane)
                    point = adsk.core.Point3D.create(ywerte[i], -xwerte_offset[i], offset_z)
                    points.add(point)
                sketch3 = root.sketches.add(root.xZConstructionPlane)
        name = "span_at_" + str(offset_z * 10) + " mm"
        sketch3.name=name
# Event handler that reacts when the command definitio is executed which
# results in the command being created and this event being fired.
class SpanCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # Get the command that was created.
            cmd = adsk.core.Command.cast(args.command)
            onExecute = SpanCommandExecuteHandler()
            cmd.execute.add(onExecute)
            # Connect to the command destroyed event.
            onDestroy = SpanCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            # Get the CommandInputs collection associated with the command.
            inputs = cmd.commandInputs
            # Create the inputs
            i1 = inputs.addSelectionInput("SketchCurve", "Kurve oben", "Please select curve")
            i1.addSelectionFilter(adsk.core.SelectionCommandInput.SketchCurves)
            i1.addSelectionFilter(adsk.core.SelectionCommandInput.RootComponents)
            i2 = inputs.addSelectionInput("SketchCurve", "Kurve unten", "Please select curve")
            i2.addSelectionFilter(adsk.core.SelectionCommandInput.SketchCurves)
            i2.addSelectionFilter(adsk.core.SelectionCommandInput.RootComponents)
            i3 = inputs.addSelectionInput("SketchCurve", "Kurve mitte", "Please select curve")
            i3.addSelectionFilter(adsk.core.SelectionCommandInput.SketchCurves)
            i3.addSelectionFilter(adsk.core.SelectionCommandInput.RootComponents)
            i4 = inputs.addValueInput('anzahl_punkte_4', '1/4 Punkte Eiform', '', adsk.core.ValueInput.createByReal(9))
            i5 = inputs.addSelectionInput("ConstructionPlane", "Parallele Ursprungsebene", "Select Plane")
            i5.addSelectionFilter(adsk.core.SelectionCommandInput.ConstructionPlanes)
            i5.addSelectionFilter(adsk.core.SelectionCommandInput.RootComponents)
            i6 = inputs.addValueInput("ValueInput", "Abstand Spanten", "mm", adsk.core.ValueInput.createByReal(0.5))
            i7 = inputs.addValueInput('anzahl_spans', 'Anzahl Spanten gleichen Abstands', '', adsk.core.ValueInput.createByReal(0))
            i8 = inputs.addBoolValueInput('checkbox', 'Erster Spant bei 0.0', True, '', False)
            i9 = inputs.addStringValueInput("Spanten semikolongetrennt", "Offsetwerte, semikolongetrennt in mm", "")
        except:
            if ui:
def run(context):
    try:
        title = 'Select Construction Plane'
        if not design:
            ui.messageBox('No active Fusion design', title)
            return
        commandDefinitions = ui.commandDefinitions
        # Get the existing command definition or create it if it doesn't already exist.
        cmdDef = commandDefinitions.itemById("SpanCMDDef")
        if not cmdDef:
            cmdDef = commandDefinitions.addButtonDefinition("SpanCMDDef",
                                                            "Span Parameters", "Creates span spline on selected construction plane")
        # Connect to the command created event.
        onCommandCreated = SpanCommandCreatedHandler()
        # Execute the command definition.
        inputs = adsk.core.NamedValues.create()
        cmdDef.execute(inputs)
        # Prevent this module from being terminated when the script returns, because we are waiting for event handlers to fire.
    except:
        if ui:
Jorge_Jaramillo
I believe you can create and remove input commands dynamically (I never tried it before), but I think a good option is to create all commands from the CommandCreateHandler event, and then control with a RadioButtonCommand which of them should be enabled or disabled according with its selection, and also dynamically set their isVisible property value from the CommandInputChange event handler.
Here is an example of how to do it, with "choice" radioButton it controls input1 and input2 enabled:
T02_CHOICE_COMMAND_ID = "choice"
T02_INPUT1_COMMAND_ID = "input1"
T02_INPUT2_COMMAND_ID = "input2"
_handlers = []
    def __init__(self):
        super().__init__()
        try:
            if cmdDef:
                cmdDef.deleteMe()
            adsk.terminate()
        except:
    def __init__(self):
        super().__init__()
        try:
                sels.clearSelection() # comment this line to kept previous selections
            elif args.input.name == T02_CHOICE_COMMAND_ID:
                choice: adsk.core.RadioButtonGroupCommandInput = args.inputs.itemById(T02_CHOICE_COMMAND_ID)
                in1: adsk.core.ValueCommandInput = args.inputs.itemById(T02_INPUT1_COMMAND_ID)
                in2: adsk.core.ValueCommandInput = args.inputs.itemById(T02_INPUT2_COMMAND_ID)
                if choice.selectedItem.name == "choice 1":
                    in1.isEnabled = True
                    in2.isEnabled = False
                else:
                    in1.isEnabled = False
                    in2.isEnabled = True
        except:
    def __init__(self):
        super().__init__()
        try:
        except:
    def __init__(self):
        super().__init__()
        global _handlers
        try:
            choice: adsk.core.RadioButtonGroupCommandInput = \
                inputs.addRadioButtonGroupCommandInput(T02_CHOICE_COMMAND_ID, T02_CHOICE_COMMAND_ID)
            choice.listItems.add("choice 1", True)
            choice.listItems.add("choice 2", False)
            in1 = inputs.addValueInput(T02_INPUT1_COMMAND_ID, T02_INPUT1_COMMAND_ID, "mm", adsk.core.ValueInput.createByReal(1.0))
            in2 = inputs.addValueInput(T02_INPUT2_COMMAND_ID, T02_INPUT2_COMMAND_ID, "mm", adsk.core.ValueInput.createByReal(2.0))
        except:
def commandTests():
    global _handlers
    try:
        if not cmdDef:
        cmdDef.execute()
    except:
This is what you get:
You can choose either to hide or to disable the commands you don't want the user interact with.
Jorge Jaramillo
joergDVRXK
Hi Jorge, exactly what i needed, thanks a lot.
Jörg
