Looking for a plug-in example.
RubyRedRick
RubyRedRick
I want to write a plug-in which will add to the active sketch. My use case is sketching fret locations for a stringed instrument.
I want to be able to select two lines which represent the nut and bridge, and use those to determine the fret positions.
I’ve been unable to find example code for a plug-in or a script to get me started.
Does anyone have any ideas?
BrianEkins
When you run the Scripts and Add-Ins command, there is a "Create" button. You'll want to create a Python add-in. That will create a starting add-in. From there you'll want to read the user manual. I think what you'll want is a command that has a dialog and probably two selection inputs to let you select the nut and bridge lines. You can possibly be flexible as to whether those are sketch lines or edges of a solid. You can also add inputs for any other variables the user can specify. Finally, you can create the final geometry. You'll need to decide if this is a sketch command that would require the user to first create a sketch and then run the command while the sketch is active or is it a modeling command and the result is to create a new sketch that creates lines that represent the frets.
Brian Ekins
RubyRedRick
I know how to create one. What I need are a code example or two which take command inputs and manipulate the active sketch. None of the example I can find touch on this.
