Link to viewer on A360 portal
akonovalenko
akonovalenko
Does anyone know how to cook link to the A360 viewer base on data from Fusion360 API?
Looks like it consists of HubId and ProjectId which are not accessible from Fusion API 😞 The ProjectId  is not accessible due to bug in FusionAPI and HubId is not available even in theory
Link example https://myhub.autodesk360.com/ue2862ee6/g/projects/D2016111651377131/data/dXJuOmFkc2sud2lwcHJvZDpmcy...
goyals
We are working on adding a new API on DataFile to get public link of a design which can be shared with others. Similar to https://www.autodesk.com/products/fusion-360/blog/share-a-public-link-of-your-fusion-360-design available in UI. Are you looking for something similar? Thanks.
Shyam Goyal
Sr. Software Dev. Manager
akonovalenko
Yes, thank you. It will help me to solve this particular issue.
But  HubId and ProjectId attributes are still werry important fto manipulate with data thru the FORGE API https://forge.autodesk.com/en/docs Otherwise to define where exactly F3D file located in A360 storage we need to scan ALL projects in all hubs on A360 to which user has an access
