LightBulbOn the Root Component
kandennti
Mentor Mentor
kandennti
Hi there.
This is not a state that happens very often, but is there any way to determine if the root component is visible?
If it is an occurrence, I can determine this with the isLightBulbOn property, but I don't think the root component is applicable. I also checked the design object but could not find it.
kandennti
Here is the only way I found.
# Fusion360API Python
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        print(isLightBulbOn_RootComp())
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def isLightBulbOn_RootComp():
    sels: adsk.core.Selections = app.userInterface.activeSelections
    sels.clear()
    root: adsk.fusion.Component = app.activeProduct.rootComponent
    sels.add(root)
    res = app.executeTextCommand(u'VO.CheckPathVisibility')
    sels.clear()
    return res.split('.')[0].upper() == 'TRUE'
I would like to avoid it if possible, because it uses text commands and requires selection.
BrianEkins
Ideally, the Component object should support the isLightBulbOn property, but it will only apply for the root component. All other "components" that are displayed are accessed through an Occurrence, which controls whether it is displayed or not, so the Occurrence.isLightBulbOn property would be used for them, not the component.
Brian Ekins
