Keyboard Shortcut
Keyboard Shortcut
brad.bylls
Keyboard Shortcut
brad.bylls
I have assigned a shortcut key to a menu item for an add-in I created.
The add-in is checked to run on startup.
When I start Fusion360 again, the shortcut is gone.
Is there a way to keep the shortcut?
Brad Bylls
BrianEkins
I don't know what the difference could be but I just tried adding a shortcut to one of my add-in commands and after re-starting Fusion, the shortcut is still available.  I don't know if it's add-in specific somehow or what the problem could be.  Can you try it with an add-in on the App Store so then we can test it with the same thing?
Brian Ekins
brad.bylls
Brian,
I loaded Patrick Rainsberry's "Sheeter" add-in and added a shortcut to one of the menu items.
It did not come back when I started Fusion again.
However, It does not show up on the menu, but it is active. (I didn't try that before)
When I press Shift + C, the menu item works.
Tried it on my code and get the same thing.
It works, just doesn't show up on the menu.
Brad Bylls
kandennti
Hi @brad.bylls .
Here is how to get a list of registered keyboard shortcuts (hotkeys) that I know of.
Run the following text command
HotKey.Export
This will export the list in json format.
For the exported file, run the following text command
Paths.Get
You will see a lot of paths, but look at the "cloudCacheDirectory" folder.
You can use @JeromeBriot  add-in "Fusion 360 Open folders" to easily open the folders.
https://github.com/JeromeBriot/fusion360-open-folders
The file "hotkey.json" in the folder is a list of Hotkeys.
Make sure that the CommandID you want to check is in this file.
Also, I haven't checked, but when you execute the addButtonDefinition method, do you set the resourceFolder?
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-04eb6198-72cd-4430-a6a4-8d68a1105b8e
If not, you may not be able to register it with Hotkey because it cannot be pinned.
