Keyboard Shortcut for Toggling Between Input Fields
Jacobsacc
Jacobsacc
I often use commands like Split Body in Fusion, where I need to switch between different input fields ("Select Body" and "Splitting Tools"). Currently, I have to click each field manually with the mouse, which interrupts the workflow and slow down the process.
It would be incredibly helpful if a keyboard shortcut (like TAB) could be implemented to toggle between these input fields in the command dialog.
I created a post in the Design, Validate & Document forum but haven't received a response. Am I missing something? Does a function like this already exist?
tiktuk
This is one of the things I miss most in Fusion in general. Wish it was standard in the UI, like in other applications.
