Keep dialog box open
brad.bylls
brad.bylls
I have a script that opens a dialog box for user input.
After the user fills in the blanks and presses ok, I would like to blank the input fields and keep the box open so the user can repeat the command.
Is this possible and how can I do it?
Thank you.
Brad Bylls
BrianEkins
In Inventor, some commands had an "Apply" button that would do something similar to what you described, but Fusion doesn't support that. You might be able to restart your command when the current instance is terminated. I think that might have a similar effect.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
brad.bylls
OK. Thanks.
Brad Bylls
kandennti
Hi @brad.bylls .
I can't keep it open, but what about a way to make it redisplay until I make the necessary entries instead?
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Please enter a number.'
        while True:
            inputTxt, isCancel = ui.inputBox(msg, 'Enter a number', '')
            if isCancel:
                return
            elif len(inputTxt) < 1:
                msg = 'Blank space is invalid.\n Please enter a number.'
            elif not isFloat(inputTxt):
                msg = 'Non-numeric characters are invalid.\n Please enter a number.'
            else:
                break
        ui.messageBox(inputTxt)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def isFloat(value) -> bool:
    try:
        float(value)
        return True
    except:
        return False
