Issues developing Fusion 360 Plugin for OS X in XCode - missing header and lib
Hello, I'm working on a C++ Fusion 360 Plugin for mac.  I am getting errors in XCode as the lib and include paths are empty and non-existent.  How do I get the libs and headers?  Thanks in advance!
$(USER_LIBRARY_DIR)/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/CPP/include
$(USER_LIBRARY_DIR)/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/CPP/lib
goyals
I am really surprised to hear it because this problem was never noticed on Mac and only impacted Windows. Just to keep you going, I attached the include and lib folder for Mac here. I hope it helps.
Shyam Goyal
Sr. Software Dev. Manager
goyals
Not sure If you mistakenly deleted it and now they are not copied again. Can you try to delete Version.text present at "
/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/version.txt" and restart Fusion? I am hoping that it should come back on restart of Fusion. We just verified on Fusion production and it is working fine for us. Thanks.
Shyam Goyal
Thank you!  It turns out that I was looking in the wrong place.  The path to the lib and include folder were specified incorrectly in the plugin that i was using as a template for my plugin, namely $(USER_LIBRARY_DIR)/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API
However, when i go to $(USER_LIBRARY_DIR)/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API, I can find all the files needed.
Thank you again, appreciate the help!
