Issue with createFromCAMTemplate2 - Need to Add Operations to the Start of the Setup
fusionPTYNN
Message 1 of 1
fusionPTYNN
Hello Fusion 360 Community,
I hope this message finds you well. I'm currently facing an issue with the `createFromCAMTemplate2` function in my Python script. When using this function, the new operations are added to the end of the parent setup. However, I need them to be added to the start of the setup.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get the active document.
        doc = app.activeDocument
        # From the Products collection on the active document, get the CAM Product.
        cam: adsk.cam.CAM = doc.products.itemByProductType('CAMProductType')
        # Check if anything was returned.
        if cam == None:
             ui.messageBox('There is no CAM data in the active document')
             return
        camManager = adsk.cam.CAMManager.get()
        templateLibrary = camManager.libraryManager.templateLibrary
        LocalFolder = templateLibrary.urlByLocation(adsk.cam.LibraryLocations.LocalLibraryLocation)
        templateLibs = getLibrariesURLs(templateLibrary, LocalFolder)
        for libUrl in templateLibs:
                if 'Vacuum' in libUrl:
                    url = adsk.core.URL.create(libUrl)
                    break
        VacuumTemplate = templateLibrary.templateAtURL(url)
        setups = cam.setups
        newVacuumOperation = adsk.cam.CreateFromCAMTemplateInput.create()
        newVacuumOperation.camTemplate = VacuumTemplate
        for setup in setups:
           setup.createFromCAMTemplate2(newVacuumOperation)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getLibrariesURLs(libraries: adsk.cam.ToolLibraries, url: adsk.core.URL):
    ''' Return the list of libraries URL in the specified library '''
    urls: list[str] = []
    libs = libraries.childAssetURLs(url)
    for lib in libs:
        urls.append(lib.toString())
    for folder in libraries.childFolderURLs(url):
        urls = urls + getLibrariesURLs(libraries, folder)
    return urls
I have multiple setups, and I want the new vacuum operations to be added to the start of each setup, not the end.
I've reviewed the Autodesk Fusion 360 API documentation, but I couldn't find a direct solution. If anyone has encountered a similar issue or has suggestions on how to achieve this, your guidance would be greatly appreciated.
Thank you in advance for your time and assistance!
Replies (0)
