Is there access to the Display Settings / Environment options?
Joshua.mursic
Joshua.mursic
I am trying to have my addon change the background color of the environment, depending on what mode that addon is in. Is there a way to activate the different environment options (Dark Sky, Grey Room etc...)? And is it possible to create new environment color options?
Kind regards,
Josh
BrianEkins
The environments aren't directly exposed through the API. However, you can access the environment command through the API and interact with it to get and set the current environment.  Below is some example code that contains a test function and two helper functions that let you get and set the environment. When getting and setting which item in the list is active, I chose to use the index instead of the name so it will work when Fusion is set to any language.
def run(context):
    app: adsk.core.Application = adsk.core.Application.get()
    ui = app.userInterface
    try:
        SetEnvironment(ui, 'Dark Sky')
        envName = GetEnvironment(ui)
        app.log(envName)
        SetEnvironment(ui, 'Tranquility Blue')
        app.log(envName)
    except:
        ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def GetEnvironment(ui: adsk.core.UserInterface) -> str:
    viewCmd = ui.commandDefinitions.itemById('ViewEnvCommand')
    listCntrl: adsk.core.ListControlDefinition = viewCmd.controlDefinition
    if listCntrl.listItems[0].isSelected:
        return 'Dark Sky'
    elif listCntrl.listItems[1].isSelected:
        return 'Grey Room'
    elif listCntrl.listItems[2].isSelected:
        return 'Photo Booth'
    elif listCntrl.listItems[3].isSelected:
        return 'Tranquility Blue'
    elif listCntrl.listItems[4].isSelected:
        return 'Infinity Pool'
    elif listCntrl.listItems[5].isSelected:
        return 'River Rubicon'
    else:
        return 'Unknown'
Brian Ekins
Joshua.mursic
Thanks so much Brian! Really appreciate the help!
Joshua.mursic
Hey Brian,
I do not see the SetEnviroment() function in your example code that you provided
BrianEkins
Oops. Sorry about that. Here it is.
def SetEnvironment(ui: adsk.core.UserInterface, envName: str) -> bool:
    if envName == 'Dark Sky':
        listCntrl.listItems[0].isSelected = True
    elif envName == 'Grey Room':
        listCntrl.listItems[1].isSelected = True
    elif envName == 'Photo Booth':
        listCntrl.listItems[2].isSelected = True
    elif envName == 'Tranquility Blue':
        listCntrl.listItems[3].isSelected = True
    elif envName == 'Infinity Pool':
        listCntrl.listItems[4].isSelected = True
    elif envName == 'River Rubicon':
        listCntrl.listItems[5].isSelected = True
    else:
        return False
    return True
Brian Ekins
Joshua.mursic
Thanks!
