Is there a way to batch delete curves?
I find that deleting (many) curves via the API is extremely slow (on the order of 200ms to 250ms per curve). Is there an API call I can make that will delete a list of curves?
If I can't batch delete I'm going to have to collect the lines i want to keep and project them into a new sketch instead which is silly Smiley Frustrated
ekinsb
This is a good request and something I've added to our backlog and I hope we can provide it soon.
Brian Ekins
Mod the Machine blog
edwinBN4C3
Deleting curves is still insanely slow.
I have a situation where I construct geometry, offset it, and then want to delete the original geometry.
In some cases before I was able to directly construct the offset geometry, but in this case that is proving ... awkward.
Is there a fast way to delete a set of curves?
marshaltu
Did you try "Product::deleteEntities" to batch delete curves? The following sample demos how to delete lines and arcs from a sketch.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        sketch = root.sketches.item(0)
        entities = adsk.core.ObjectCollection.create()
        for line in sketch.sketchCurves.sketchLines:
            entities.add(line)
        for arc in sketch.sketchCurves.sketchArcs:
            entities.add(arc)
        design.deleteEntities(entities)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
edwinBN4C3
Cool, I'll have to give it a try. Thanks!
