Is there a script to push the Part Name to the Description?
tookemtoni
tookemtoni
tookemtoni
I got this work but only for one component at a time.  I would to this to work on multiple selections...Is that possible?
import adsk.core
import adsk.fusion
import traceback
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        # Get the active selection in Fusion 360
        selections = ui.activeSelections
        if selections.count == 0:
            ui.messageBox("No components selected. Please select one or more components.")
            return
        for selection in selections:
            if isinstance(selection.entity, adsk.fusion.Occurrence):
                component = selection.entity
                part_name = component.name
                # Update the Description to match the Part Name
                component.component.description = part_name
        ui.messageBox("Updated the Description for selected components.")
    except:
        if ui:
            ui.messageBox("Error: " + traceback.format_exc())
if __name__ == "__main__":
    run(None)
kandennti
Hi @tookemtoni .
Try this.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        des: fusion.Design = app.activeProduct
        comp: fusion.Component = None
        for comp in des.allComponents:
            comp.description = comp.name
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
tookemtoni
@kandennti Done.... Thank you!
