Is it possible to specify CAM SETUP WCS Work Coordinate System based on origin point and XYZ vectors via API
omedvydskiy
omedvydskiy
I have origin point and vectors xAxis, yAxis, zAxis.
I want to specify workCoordinateSystem for CAM setup.
Method setWithCoordinateSystem returns True but it does not work.
setup.workCoordinateSystem.setWithCoordinateSystem(origin, xaxis, yaxis, zaxis)
Jorge_Jaramillo
Just to check, could you post the results of
app.lof(f'{setup.workCoordinateSystem.asArray()=}')
before and after you change it?
The result of it is printed in the Text Commands window, below in Fusion's screen.
And also the values of origin.asArray(), xaxis.asArray(), yaxis.asArray(), zaxis.asArray()?
omedvydskiy
Jorge_Jaramillo
Hi @omedvydskiy ,
I was able to reproduce the same situation on my environment.
Looking at the documentation for Setup.workCoordinateSystem Property, it states only to GET its value and it doesn't say anything about setting it:
I made two additional tests:
- Try to assign a new matrix to setup.workCoordinateSystem: got this error : AttributeError: can't set attribute
- Get the matrix that setup.workCoordinateSystem contains, and update it with setWithCoordinateSystem().  It allowed me to update the matrix but the changes are not reflected in the setup property.
Conclusion: I don't thing it is possible to update it at the moment.
Jorge Jaramillo
Software Engineer
omedvydskiy
Thanks for replay.
jonathan_davisJNRKK
I'm on this rabbit trail right now... Is it not possible to set it using an input parameter?
setup.parameters.itemByName('wcs_orientation_axesZX_unselected_default').expression = # reference geometry somehow???
