Is it possible to Select the Convert mesh Method using the API?
nfernandezV9ZRM
nfernandezV9ZRM
Curious if anyone has encountered a similar situation and found a solution.
I'm trying to run the convert mesh command, but I also want to dictate which method is used for the conversion.
_app.executeTextCommand(u'Commands.Start ParaMeshConvertCommand') # Unsure how to change the parameters for this operation
        # ¯\_(ツ)_/¯
            # push "OK" button
            _app.executeTextCommand(u'NuCommands.CommitCmd')
kandennti
Hi @nfernandezV9ZRM -San.
I think you can switch in this way.
        # show dialog
        _app.executeTextCommand(u"Commands.Start ParaMeshConvertCommand")
        # set operation
        _app.executeTextCommand(u"Commands.SetString ConvertMeshInfoOperation {}".format("infoOperationParametricFeature")) # Parametric
        # _app.executeTextCommand(u"Commands.SetString ConvertMeshInfoOperation {}".format("infoOperationNewBaseFeature")) # Base Feature
        # set method
        # _app.executeTextCommand(u"Commands.SetString MeshToBREPAlgorithmInput {}".format("infoMethodTriangleBased")) # Faceted
        _app.executeTextCommand(u"Commands.SetString MeshToBREPAlgorithmInput {}".format("infoMethodPrismatic")) # Prismatic
        # _app.executeTextCommand(u"Commands.SetString MeshToBREPAlgorithmInput {}".format("infoMethodOrganic")) # Organic
        # push "OK" button
        _app.executeTextCommand(u"NuCommands.CommitCmd")
