Is it possible to isolate a component via API?
luca.giorcelli9CG7C
luca.giorcelli9CG7C
I'm trying to isolate a component via API in order to export a thumbnail using Viewport.saveAsImageFile(filename, width, height). I've hundreds of component, so I need to do that programmatically.
In the API reference I cannot find any method to accomplish this simple task.
Any help is appreciated.
Rushikesh.kadam
@luca.giorcelli9CG7C here are few references I found related to isolation of component.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-bb040782-b1b0-4ffe-b0f7-3cd97533b9c5
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7cd5b52f-26bb-4890-9c37-2dc48213d685
Also, refer to below sample code where in I created two components and then isolated one and performed unisolate operation on the same component.
import adsk.core, adsk.fusion, traceback
import time
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        # Create a document.
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # Get the root component of the active design
        rootComp = design.rootComponent
        # Get extrude features
        extrudes = rootComp.features.extrudeFeatures
        # Create sketch
        sketches = rootComp.sketches
        sketch = sketches.add(rootComp.xZConstructionPlane)
        sketchCircles = sketch.sketchCurves.sketchCircles
        centerPoint = adsk.core.Point3D.create(0, 0, 0)
        circle = sketchCircles.addByCenterRadius(centerPoint, 5.0)
        # Get the profile defined by the circle
        prof = sketch.profiles.item(0)
        # Create another sketch
        sketchVertical = sketches.add(rootComp.yZConstructionPlane)
        sketchCirclesVertical = sketchVertical.sketchCurves.sketchCircles
        centerPointVertical = adsk.core.Point3D.create(0, 10, 0)
        cicleVertical = sketchCirclesVertical.addByCenterRadius(centerPointVertical, 0.5)
        # Get the profile defined by the vertical circle
        profVertical = sketchVertical.profiles.item(0)
        distance = adsk.core.ValueInput.createByReal(5)
        extrude1 = extrudes.addSimple(prof, distance, adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
        distance2 = adsk.core.ValueInput.createByReal(5)
        extrude2 = extrudes.addSimple(profVertical, distance2, adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
        occ1 = rootComp.allOccurrences.item(0)
        occ1.isIsolated = True
        ui.messageBox('Component 1 isloated. It will be unisolated on OK')
        occ1.isIsolated = False
    except:
        ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
If it works out, do click on accept solution button.
Rushikesh Kadam
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
luca.giorcelli9CG7C
It was so simple!!!
isIsolated
But where is located this command in the API reference?
Rushikesh.kadam
Here is the link to reference
If it worked out, do click on accept solution button.
Rushikesh Kadam.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
