is a point inside a body ?
lionel.courgnaud
lionel.courgnaud
I'm trying to solve this case. I'm having a body and 2 sketches lines (OA, OB)
I'd like to know if the AOB angle is in the body or not.
I tried to draw a construction line (AB)  and determine if his middle is inside the body, but I'm stuck.
Is there a function for that ? Or a better way to do it ?
Thanks for your help 🙂
BrianEkins
You can use the BRepBody.pointContainment method to determine if a point is inside, on, or outside a body.
Brian Ekins
lionel.courgnaud
thanks a lot 🙂 it's so easy when you know the good API function 🙂
