Invalid Input Target for BRepBody.movetToComponent
I'm trying to move a body from one component to another using the code below. I get an Invalid Input Target Runtime error. I know the occurence target exists. What would cause this error?
for body in self.objectBodySet:
            body.moveToComponent(self.rwoOccurences().item(0))
        for body in self.holderBodySet:
            body.moveToComponent(self.holderOccurences().item(0))
def rwohOccurences(self):
        occs =self.design.rootComponent.allOccurrencesByComponent(self.RWOH)
        if occs.count==0:
            self.ui.messageBox("no occurences")
        return self.design.rootComponent.allOccurrencesByComponent(self.RWOH)
ekinsb
Can you please provide a full reproducable case for this.  There are several different things that could impact this and having a case that demonstrates the problem will make it much easier.  Ideally a .f3d file and the full script, the simpler the better.  Thanks.
Brian Ekins
Mod the Machine blog
I have discovered the problem. I had been passing around a Design variable from my ui controllor to a variety of classes. But I never updated the design when I switched between documents which results in all sorts of weird errors.
