Intersection Curve from two splines
0xHexdec
0xHexdec
Hey all,
I am trying to get the intersection curve from two splines via API.
I just want to reproduce the result I am getting when I use the "Intersection Curve" Command in the Sketch workspace, but I can't find it anywhere.
cheers
kandennti
Hi @0xHexdec .
Since the API did not seem to provide the functionality, we used a text command.
Please make the attached f3d file active and run the following script.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        crv1: adsk.fusion.SketchEntity = root.sketches[0].sketchCurves[0]
        crv2: adsk.fusion.SketchEntity = root.sketches[1].sketchCurves[0]
        intersectionCurve: adsk.fusion.SketchEntity = execIntersectionCurve(crv1, crv2)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def execIntersectionCurve(
    crv1: adsk.fusion.SketchEntity,
    crv2: adsk.fusion.SketchEntity,
    skt: adsk.fusion.Sketch = None,) -> adsk.fusion.SketchEntity:
    ui: adsk.core.UserInterface = app.userInterface
    sels: adsk.core.Selections = ui.activeSelections
    if not skt:
        skt = root.sketches.add(root.xYConstructionPlane)
    sktEntsCount = skt.sketchCurves
    sels.add(skt)
    app.executeTextCommand(u'Commands.Start SketchActivate')
    app.executeTextCommand(u'Commands.Start IntersectionCurve')
    sels.add(crv1)
    sels.add(crv2)
    try:
        app.executeTextCommand(u'NuCommands.CommitCmd')
    except:
        pass
    finally:
        app.executeTextCommand(u'NaFusionUI.SketchStopCmd')
    if sktEntsCount == skt.sketchCurves.count:
        return None
    else:
        return skt.sketchCurves[-1]
If you select a curve for which the command succeeds in the GUI, it is OK, but if you select a curve for which the command fails, you will get an error.
I need some logic to determine if it will fail beforehand, but I haven't come up with it.
0xHexdec
As the solution above by @kandennti was a good, valid, and very clean but only works in scripts and not in Add-Ins due to the weirdness of TextCommands (see: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/creating-a-custom-command-dialog-then-runn...) I implemented a workaround by projecting to a surface. The result is almost the same except the project gets polluted by surface bodys. But at least this works reliably under all circumstances.
Open the attached .f3d file and run the script.
import traceback
import adsk.core
import adsk.fusion
def run(context):
    app = adsk.core.Application.get()
    try:
        rootComponent = adsk.fusion.Design.cast(app.activeProduct).rootComponent
        # finding Top Spline
        top_spline_sketch = rootComponent.sketches.itemByName("Top_Spline")
        top_spline = top_spline_sketch.sketchCurves.sketchControlPointSplines.item(0)
        # finding Side Spline
        side_spline_sketch = rootComponent.sketches.itemByName("Side_Spline")
        side_spline = side_spline_sketch.sketchCurves.sketchControlPointSplines.item(0)
        extrudes = rootComponent.features.extrudeFeatures
        # define a path from the sketch curves
        path = rootComponent.features.createPath(top_spline, False)
        # set parameters to extrude surfaces according to the profileCollection
        extrudeInput = extrudes.createInput(path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        extrudeInput.setSymmetricExtent(adsk.core.ValueInput.createByReal(50), False, adsk.core.ValueInput.createByReal(0))
        # indiciate that the extrude should be a surface, not a solid
        extrudeInput.isSolid = False
        # extrude and get the created body
        body = extrudes.add(extrudeInput).bodies.item(0)
        newSketch: adsk.fusion.Sketch = rootComponent.sketches.add(rootComponent.xYConstructionPlane)
        newSketch.name = "Intersection Curve"
        ret = newSketch.projectToSurface([body.faces.item(0)], [side_spline], adsk.fusion.SurfaceProjectTypes.AlongVectorSurfaceProjectType, rootComponent.xConstructionAxis)
        body.isLightBulbOn = False
    except:
        if ui:
MichaelT_123
Have you tried:
(returnValue, intersectingCurves, intersectionPoints) = sketchCurve_var.intersections(sketchCurves)
Regards
MichaelT
MichaelT
0xHexdec
@MichaelT_123
Thanks for the reply, but your solution does not create an intersection curve, it checks for curve intersections
The "Intersection Curves" Tool in Fusion's Sketch Environment creates a 3-Dimensional line based on 2 orthogonal 2D sketchlines.
