InternalValidationError when using JointOrigins
I have a model with two Joint Origins. The body is extruded form a sketch and one origin is in the centre of the face and the other the centre of the fillet:
When I try to determine the position of the joint origins using the following code, the first works but the second throws an internal validation exception:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    try:
        app = adsk.core.Application.get()
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        for jointOrigin in rootComp.allJointOrigins:
            print(jointOrigin.name)
            try:
                print(jointOrigin.geometry.origin.asArray())
            except Exception as e:
                print(e)
    except:
        print('Failed:\n{}'.format(traceback.format_exc()))
and the output:
Joint Origin1
(0.0, -2.5, 6.0)
Joint Origin2
2 : InternalValidationError : jointGeom->entityTwo_
goyals
@Anonymous Please share the design if possible so I can look at that.
Shyam Goyal
Sr. Software Dev. Manager
Attached
goyals
Thank you for sharing the design. We fixed this as well along with the other issue you reported. It will make to Fusion production in month of October.
Shyam Goyal
