InternalValidationError when creating construction plane
Tim.Overbye
Tim.Overbye
Howdy,
I have a script to generate a half sphere and place holes in its surface randomly. It works fine for the first 10-20 holes then throws an error.
Failed:
Traceback (most recent call last):
  File "C:/Users/Tim/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Star_form/Star_form.py", line 111, in run
    workplane = rootComp.constructionPlanes.add(workplaneinput)
  File "C:/Users/Tim/AppData/Local/Autodesk/webdeploy/production/6783e6b71d33852e05099c507cf8d926394ea32c/Api/Python/packages\adsk\fusion.py", line 12795, in add
    return _fusion.ConstructionPlanes_add(self, input)
RuntimeError: 2 : InternalValidationError : data_->execute(&obj, apiName) && obj
I'd appreciate any help, the full code is below.
#Author-
#Description-
from tkinter.messagebox import NO
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
import random
id = 300*0.1
wall_thickness = 2 * 0.1
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        # Draw arcs.
        arc = sketch.sketchCurves.sketchArcs
        arc1 = arc.addByCenterStartSweep(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(id/2, 0, 0),math.pi)
        arc2 = arc.addByCenterStartSweep(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(id/2 + wall_thickness, 0, 0),math.pi)
        # Draw lines to close arcs.
        lines = sketch.sketchCurves.sketchLines
        line_1 = lines.addByTwoPoints(adsk.core.Point3D.create(id/2, 0, 0), adsk.core.Point3D.create(id/2 + wall_thickness, 0, 0))
        line_2 = lines.addByTwoPoints(adsk.core.Point3D.create(-id/2, 0, 0), adsk.core.Point3D.create(-id/2 - wall_thickness, 0, 0))
        # Draw center line to use as the axis of revolution.
        axisLine = lines.addByTwoPoints(adsk.core.Point3D.create(-1, 0, 0), adsk.core.Point3D.create(1, 0, 0))
        # Get the profile defined by the circle.
        prof = sketch.profiles.item(0)
        # Create an revolution input to be able to define the input needed for a revolution
        # while specifying the profile and that a new body is to be created
        revolves = rootComp.features.revolveFeatures
        revInput = revolves.createInput(prof, axisLine, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        # Define that the extent is an angle of pi to get half of a sphere.
        angle = adsk.core.ValueInput.createByReal(math.pi)
        revInput.setAngleExtent(False, angle)
        # Create the extrusion.
        ext = revolves.add(revInput)
        body = ext.bodies[0]
        target_face = None
        # Create hole on body
        basesketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
        basesketch.isVisible = False
        r = id/2 + wall_thickness
        # randomply place pt on half sphere
        for i in range(100):
                    # Get face
            for face in body.faces:
                surface = adsk.core.Sphere.cast(face.geometry)
                if (surface and math.fabs(surface.radius - (id/2 + wall_thickness)) < 1.0e-6 ):
                    target_face = face
            phi = random.random() * math.pi * 2.0
            theta = random.random() * math.pi*0.5
            x = r * math.sin(theta) * math.cos(phi)
            y = r * math.sin(theta) * math.sin(phi)
            z = r * math.cos(theta)
            # Create hole based on a point
            pt = adsk.core.Point3D.create(x, y, z)
            basesketchpoint = basesketch.sketchPoints.add(pt)
            if(target_face):
                # Create plane tangent to sphere
                workplaneinput = rootComp.constructionPlanes.createInput()
                workplaneinput.setByTangentAtPoint(target_face, basesketchpoint)
                # Create hole
                holeinput = rootComp.features.holeFeatures.createSimpleInput(adsk.core.ValueInput.createByString('1 cm'))
                holeinput.setPositionByPoint(workplane, pt)
                holeinput.setDistanceExtent(adsk.core.ValueInput.createByReal(10))
                rootComp.features.holeFeatures.add(holeinput)
                # Hide workplane
                workplane.isLightBulbOn = False
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @Tim.Overbye .
I haven't checked the reason in detail, but it seems that sometimes the sketch point is not on the surface.
I'm sure there are better ways to do this, but you might want to make sure they are on the surface.
            if(target_face):
                # Check if the point is on the surface.
                if not isPointOnSurface(target_face, basesketchpoint):
                    continue
def isPointOnSurface(
    target_face: adsk.fusion.BRepFace,
    basesketchpoint: adsk.fusion.SketchPoin,
    tolerance: float = 0.0001) -> bool:
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        measMgr: adsk.core.MeasureManager = app.measureManager
        res: adsk.core.MeasureResults = measMgr.measureMinimumDistance(
            target_face,
            basesketchpoint
        if res.value > tolerance:
            return False
        return True
    except:
        return False
Tim.Overbye
Thanks, I tried what you suggested but it didn't solve the problem.
I'm still not sure what the problem was but I got it working by creating all the construction planes in a single batch and then doing all the holes in a separate batch. I think the problem was related to using the object's surface after modifying it.
BrianEkins
I looked into this a bit and believe it is some kind of bug with Fusion.  I captured the XYZ coordinates from a failed run and then used those to test with.  It consistently failed on the last point, but I can interactively create a construction plane using that point.  What's especially weird is if I reordered the last point that failed to any other location in the point set, it was successful.
I would recommend another approach to do what you're doing that should be much faster to process and I think simpler too. You can use the functionality supported by the TemporaryBRep Object. I presented a class on this at Autodesk University a few years ago and that material is available here.
Brian Ekins
Tim.Overbye
Thanks, I switched to the TemporaryBRep Object approach and everything's working now and significantly faster.
