input.setTwoSidesExtent problem
brad.bylls
brad.bylls
The code below is part of an add-in script I am developing.
This works just fine in a part of the script just above it that is almost identical.
    # Create Plate AX
    plateAXprof = moldBaseSketch.profiles[0]
    plateAXextInput = extrudes.createInput(plateAXprofadsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    deg0 = adsk.core.ValueInput.createByString("0 deg")
    distance3 = adsk.core.ValueInput.createByReal(numPlateXthickness# distance3 = 2.2225
    distance4 = adsk.core.ValueInput.createByReal((numPlateXthickness + numPlateAXthickness) * -1# distance 4 = -5.715
    plateAXextInput.setTwoSidesExtent(distance3distance4deg0deg0# numPlateAXthickness = 3.4925 - line 410
    plateAXext = extrudes.add(plateAXextInput)
This is the cryptic error message I am getting.
Can someone please explain.
Thank you.
Brad Bylls
BrianEkins
The setTwoSidesExtent method takes two ExtentDefinition objects for the first two arguments.  You're providing ValueInput objects.  Here's a modified version of your code that works for me.
numPlateXthickness = 2.2225
plateAXextInput = extrudes.createInput(plateAXprof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
distance3 = adsk.core.ValueInput.createByReal(numPlateXthickness)
distance4 = adsk.core.ValueInput.createByReal((numPlateXthickness + numPlateAXthickness) * -1)
ext1 = adsk.fusion.DistanceExtentDefinition.create(distance3)
ext2 = adsk.fusion.DistanceExtentDefinition.create(distance4)
deg0 = adsk.core.ValueInput.createByReal(0)
plateAXextInput.setTwoSidesExtent(ext1, ext2, deg0, deg0)
Brian Ekins
brad.bylls
My bad.
I looked at the code several times and just didn't get it.
Thanks so much.
Brad Bylls
